Seems to me that when on the highway the sweet spot for the super duty 7.3L for getting good gas mileage is at 70mph. It was the same way in my f250 6.2l. Does anyone else notice this?
I didn't buy my truck to worry about gas mileage. That said, these things have the aerodynamics of a brick on stilts. You will get better fuel mileage by slowing down. If you think 70mph is the "sweet spot", you should try 60mph...
This right here. My old Power Wagon (the most recent gas truck I have owned) got the best mileage at about 45 mph. Could put down almost 20 mpg at that speed (4.10's and a 6-speed trans). At 70 I got 13 mpg. Faster than that I'd be around 10...which was the same I got when towing at 65.
Newer trucks with better gears will get better mileage. But with the crappy aerodynamics, higher speeds will reduce it, because resistance due to frontal area increase as the square of speed - it's not a linear formula.
This is completely subjective by tire size, axle ratio and speed. My DRW with 31.5" tires and 4.30s would get over 20mpg at 45mph. I put 33s on it so now I get worse mileage except around 50mph I can get around 20mpg.
I would not say 70mph is a sweet spot for mpg with any tire size and gear ratio.
My dad used to tell me it was at peak torque and top gear would be your best mileage, I don't know if that's true or not.
Fuel is actually free for me, in the majority of our work is T&M, so let it burn.
Unless you're in California, or worse off Nevada after the beginning of next year. You won't have it to burn.
He was close, and in some situations he'd be right. As power goes up fuel consumption goes up but it isn't 1:1. As torque comes up you get greater and greater power returns for your increased fuel consumption and that ratio of power for fuel peaks where torque peaks, after that you can still get more power but you get diminishing returns on extra power for extra fuel consumption. Peak fuel consumption is at peak horsepower.
As far as peak mileage goes, slowing down will get you better mileage. Though the efficiency relationship between power and fuel consumption is related to torque, mileage is a function of power demand not torque. Vehicle drag increases by the speed squared so it really adds up at highway speeds so slowing down a little bit reduces power required a lot. Generally you'll get best mileage going as slow as you reasonably can in top gear. Where your dad was real close is the published peak torque values is at WOT, but as you reduce throttle the RPM of peak torque drops too. At 5% throttle the peak torque RPM will be a lot lower than at WOT. In top gear that goes hand in hand with slowing down. So if you are in top gear, and going as slow as reasonable (varies but probably about 50-55 mph) then you'll be right around peak torque for your lower throttle input and getting the best mileage.
And FWIW, I found that my '17 6.2L, 6R100 didn't get it's best mileage until the trans was warmed up to it's normal operating temp, which was close to 200F. That took a good 20-25 minutes of driving time. My '25 7.3L, 10R100 seems to be the same...taking at least as long as the '17 did to warm up to it's best op temp.
This is true, because a warmer fluid is more viscous and flows easier. Synthetic fluids start off more viscous, which is why many people who are chasing fuel mileage replace differential, t-case, trans, and motor oils with synthetic equivalents. I tried it once years ago, and picked up maybe 1mpg...but if you're chasing fuel mileage every little bit adds up.
It seems pretty simple to me.
The lowest speed you can stay in the highest gear is going to give you the highest mpg.
My 7.3 4.30 34.5” MTs 2” air deflector at 65 mph gets 14.4 mpg, at 70 mph it gets 12 mph.
The posted speed limit around here on these two lane highways is 70, so that’s the speed I go. When I’m on four lane highways I go 65 mph.
It isn't QUITE that simple, but pretty close. My current truck gets ever so slightly better mileage in 9th gear at 57 mph than it does in 10th at 60. That difference is like... less than .5 mpg.
