2011 E-350 Transmission
Old Dec 11, 2025 | 05:20 PM
trentsnowbarger's Avatar
trentsnowbarger
1st Gear
Hello all,
The transmission imploded in my van. I have gone through the effort to remove it from the vehicle, and it's now sitting on some plywood in my garage. I'm looking at finding a replacement at my local LKQ. Does this van share the same transmission as the F-250? How do I know what the model is I have now? Thanks all!
Old Dec 11, 2025 | 07:43 PM
tabijan's Avatar
tabijan
There should be a tag with a transmission code among other codes in the driver door jamb or on the trailing edge of the driver door. Look up the transmission code to identify the transmission - e.g., 4R75E, 5R110W…
I don’t know if an F250 transmission will work or what it takes to make it work. Obviously some work if the F250 is 4X4. car-part.com lists some RWD F250 transmissions as compatible.
Sixto
07 E350 5.4 200k miles
Old Dec 12, 2025 | 06:28 AM
manicmechanic007's Avatar
manicmechanic007
There should also be a tag on the side of the transmission
ArmyTruckGuy
Apr 8, 2022 06:22 AM
Michaelsueb
Jul 11, 2015 09:30 PM
PStruwing
May 9, 2012 08:26 AM
