Help please
Old Dec 2, 2025 | 07:03 PM
Chrisdub's Avatar
Chrisdub
3rd Gear
Help please
Newbie here. I did a few mods using forscan on my 2022 f250 Lariat. Have two fully charged batteries everything works just can't get it started. I press the start button everything lights up but the truck doesn't do anything. Any forscan gurus
that could tell me where to start.
Old Dec 2, 2025 | 09:34 PM
ibeb's Avatar
ibeb
Not a Forscan guru, but have used it to do adjustments on my F350 and buddies F150. I didn't run into any issues, but on his I made a change and something just wasn't working right, been a bit, so don't remember exactly what. Key thing to do is save a baseline or download one if you didn't. I also logged every change and only dis one at a time, so backing up a step was fairly easy. For his, I reset back to stock configuration and then started the process over, just going slower and everything was good.
If you have your stock configuration, I would start by setting things back to that and see if that corrects your issues.
Good luck
Erik
Old Dec 3, 2025 | 05:44 AM
speakerfritz's Avatar
speakerfritz
check to see if both battery terminals are making good contact and check the voltage of both batteries....measure at the center of the battery terminal not on the battery clamps. if there is corrosion on the battery terminals the voltage will be different at the center of the terminals vs the clamps themselves.
also..mak sure your alarm is cleared...sometimes if you fiddle with the alrm on the key fob the truck goes into stupid mode and does nothing when you try to start it.
Old Dec 3, 2025 | 06:16 AM
BPTS's Avatar
BPTS
@ZooDad
He will be your best resource.
Jeffaf
Nov 11, 2023 01:04 AM
RailDawg
2021+ F150
Jan 3, 2023 12:48 PM
DuckdiverJake
Jan 4, 2017 12:11 PM
BombThreat
Nov 25, 2014 06:13 AM
Mamma Bear
25
Jun 9, 2012 05:52 PM
