ECU info
Old Dec 2, 2025 | 01:22 PM
saemetric's Avatar
saemetric
4wd Low
ECU info
Having trouble with my 86 F150 5.0 automatic.
Idles and runs badly when warmed up. Replace CT’s, map, and air intake sensor. No improvement.
Removed ECU to check for bad capacitors. They looked fine. Here are pix of ECU labels. It seems like it is not the original ECU. Truck has been running fine for years with this ECU so that’s not the problem. Anyone know what the last V1A means. Is this ECU for a 1986 F150 5.0. Not sure what the red label means.
Old Dec 2, 2025 | 03:32 PM
FuzzFace2's Avatar
FuzzFace2
Have you checked for codes to see what it may have?
That is where I would start,
Dave ----
Old Dec 2, 2025 | 04:14 PM
Dennis Tiger's Avatar
Dennis Tiger
4wd Low
Mine is a 1985 windsor from the factory and I crossed the ecu in mine with the same as a jeep that ford was involved with building in the 80s. I bought a new one for 15$.
Old Dec 2, 2025 | 05:02 PM
Franklin2's Avatar
Franklin2
VIA is just a revision number tacked on the end.
fgcox1
Ford Truck Parts for Sale
Jul 16, 2017 02:32 PM
ExitLeft
May 18, 2013 08:34 PM
shorebird
2009 - 2014 F150
25
Oct 29, 2012 02:34 PM
ddavidv
Jul 24, 2003 03:33 PM
