Interior Lighting
Old Dec 8, 2003 | 07:51 PM
mikeal's Avatar
mikeal
Question Interior Lighting
Just replaced the multi-function switch on my 99 Expedition because the rear left signal light and left brake light won't come on, now that they're fixed another problem popped out, all the interior lights and running board lights came on and won't shut off. Any suggestions on how to fix this problem.
Old Dec 8, 2003 | 09:00 PM
pounder90's Avatar
pounder90
Make sure that all the door switches are closed including the rear door and window. Also, make sure the dash dimmer switch isn't turned all the way up. The same thing happens to my mom's 2003 Explorer. I open all her doors and close them again and then the lights go out. If that doesn't help, consider the integrity of the MFS that you just installed.
Old Dec 8, 2003 | 09:57 PM
mikeal's Avatar
mikeal
Talking Interior Lighting
You're right, it was the dimmer switch Thanks.
