Adjustable Track Bar vs. Track Bar Bracket
Old Dec 1, 2025 | 01:34 PM
Alloy's Avatar
Alloy
Looking at different 2" - 3" lift/leveling kits.
Some kits have adjustable track bars and other kits have extended track bar brackets.
What's better?
EDIT: I went to talk to a mechanic who's been a front end Ford Tech for decades.
This is what he said:
- get an adjustable track bar. More and more kits are sold as one size ( but there's 7 different factory coil springs for the F250/f350/F450) fits all so he's having to drill / weld the brackets to center the axle center. He showed me a Ready Lift bracket for a F250 he was modifying.
- get new radius arms / stay away from caster shims.
- sway bar drop or extended sway bar links both work
- use shock boots
I ended up going with a BDS 2.5" / Fox Performance Elite kit for a F450
Old Dec 1, 2025 | 04:13 PM
jimzpsd's Avatar
jimzpsd
I would prefer the solid bracket, the adjustable track bar may be a weaker link due to the threads where it adjusts. My opinion only
Old Dec 1, 2025 | 05:47 PM
davidpacificnw's Avatar
davidpacificnw
doing research now for my truck so commenting to get updates. Thx
Old Dec 1, 2025 | 06:44 PM
Alloy's Avatar
Alloy
It's a mess.
Lots of kits have 450lb coils that are less capacity than the factory coils. They tell you it's a 2.5" kit but it only gives 1.5" so you may as well save $$ and put a block on the coil.
Old Dec 1, 2025 | 09:18 PM
morehouse7's Avatar
morehouse7
Adjustable track bar will allow you to perfectly center the axle.
Old Dec 2, 2025 | 06:35 AM
honda250xtitan's Avatar
honda250xtitan
i prefer the bracket. keeps the geometry at the same angle as stock. I ran both, felt better saving $200 or whatever the carli track bar costs these days. currently have the ready lift bracket on my 2011 which has a 2.5" lift, axle is centered perfectly. I don't think anyone is going under the truck and adjusting the bar for 1/16".
Old Dec 2, 2025 | 10:27 AM
nitebreeze's Avatar
nitebreeze
Doing just the adjustable track bar is quicker and easier, allows you to more perfectly fine tune centering the axle, and is much more expensive. I agree that the adjustable track bar is probably not as heavy duty as a solid track bar. Doing just the track bar relocation bracket is more bolts and a little inconvenient but is still easy and much less expensive.
Old Dec 2, 2025 | 07:36 PM
honda250xtitan
Either option= you gotta get that one bolt 400ftlbs lol
Old Dec 2, 2025 | 08:52 PM
JoeUser's Avatar
JoeUser
Yep, that's what's holding up installing my PMF track bar (HD Offroad version). I don't have a torque wrench that handles anywhere near that torque...
https://www.pmfsuspension.com/2005-2...link_p_28.html
I'll probably end up paying a shop to install it, and get aligned at the same time.
Old Dec 3, 2025 | 07:15 AM
jimzpsd's Avatar
jimzpsd
406 ft.lbs. lol
Old Dec 3, 2025 | 07:17 AM
jimzpsd's Avatar
jimzpsd
If you have an electric or pneumatic 1/2" impact, apply max setting and send it.
Old Dec 3, 2025 | 07:20 AM
B-ManFX4's Avatar
B-ManFX4
Unless the bracket exactly matches the lift, the geometry will not be perfect or better than using an adjustable track bar. The PMF unit, even though it is threaded, is plenty strong for these trucks.
I tried both and the PMF trackbar allowed me to perfectly center the axle. The bracket did not center it perfectly on my truck.
For what it is worth, you can have the bracket if you will pay the shipping from me to you. PM me if you are interested in it.
Old Dec 3, 2025 | 07:37 AM
JoeUser's Avatar
JoeUser
I was thinking exactly that, only follow it up with a long pipe and breaker bar for a final tug. And, some red Loctite threadlocker...
I've got the track bar sitting in the garage, along with the adapter for the steering damper. Just going to wait for a semi-warm afternoon to crawl up under the truck and get after it. I don't relish lying on cold concrete to do it, though, lol...
Old Dec 3, 2025 | 11:02 AM
morehouse7's Avatar
morehouse7
I did not use an adjustable track bar and went with this bracket, it's supposed to better maintain the proper geometry. My axle is almost perfectly centered
https://bisonoffroad.com/product/tra...4wd-2008-2025/
I have checked the torque before, I just send it with the 1/2" Milwaukee impact and it's tight beyond 405...
Old Dec 3, 2025 | 11:12 AM
speakerfritz's Avatar
speakerfritz
how would we know its center? Need a jig or something? On my front axle the axle pumpkin is not centered so can’t use and pumpkin bolts to inside frame measurements to compute centerness? That why I always just get the relocation bracket based on lift height.
