1994 Electrical issue
Old Nov 22, 2025 | 11:21 PM
PWRSTK2K's Avatar
PWRSTK2K
Smile 1994 Electrical issue
Drove to Walmart everything is fine, come out of WM start truck - ABS light is on, No radio, Heater, pwr windows and turn signals. Dark and cold tonight so going to start tomorrow. Tips/Ideas on where to start looking? It's F250 XLT automatic 4WD.
Old Nov 23, 2025 | 05:23 AM
manicmechanic007's Avatar
manicmechanic007
Check your ignition switch
They like to separate where the pot metal meets the plastic, and then they do not always work correctly
Next time it happens, try wiggling the key around slightly, see if the radio and heater etc. come back on
Fun stuff
Old Nov 23, 2025 | 12:03 PM
PWRSTK2K's Avatar
PWRSTK2K
Smile
Thanks a lot Manic for quick reply, seems like I had to replace switch bout 10 yrs ago. If this is culprit do you recommend OEM or aftermarket. Current one is aftermarket.
Old Nov 24, 2025 | 04:19 AM
manicmechanic007
I would go with OEM Ford, but they were the ones that started fires
The new ones were supposed to have that problem fixed (after the big recall in / around 1995)
Did you wiggle the switch around and have the problem go away?
Old Nov 24, 2025 | 12:51 PM
PWRSTK2K's Avatar
PWRSTK2K
Smile
Well, you could say I wiggled the switch around a bit. I started the truck up and everything was all right, back to normal, no wiggling involved. Still thinking I need to replace switch. Going to call dealer today. After some thought, remembered I replaced the ignition tumbler and key, not the ignition switch. So it's likely the original switch. I've owned truck 22 years.
Old Nov 24, 2025 | 04:41 PM
PWRSTK2K's Avatar
PWRSTK2K
Angry
Called local Ford dealer - they don't stock or no longer make switch or tumbler portion of 1994 trucks. Look like after market is my option.
swarf_rat
6.7L Power Stroke Diesel
31
May 3, 2016 03:41 PM
Steve_250
Mar 3, 2014 05:12 PM
Metacarpels
1997 - 2003 F150
Sep 30, 2004 11:35 AM
