Hi all
So for some reason the 2026 F350 Lariet that I am having built only comes with 18 inch rim and tire. Of course my question is will I encounter any real problems if I remove them and install 20's Please help I would appreciate any input
Hi all
Thanks
I presume you're either trying to avoid the Blackout package/chrome package, or you're ordering a Tremor.
As long as the final tire size remains the same as stock, you can put whatever size rims on it you want after you buy it. I will say this - more sidewall at the same or lower tire pressure acts as an insulator from the road, meaning you'll get a bit softer ride on rougher roads. My '25 F350 Tremor rides a bit softer than my '22 Ram 2500 did, despite having leaf springs in the rear instead of coils. The Ram had 20" rims with not a lot of sidewall, whereas the Tremor has 18" wheels with 35" tires, so a LOT of sidewall. Tire pressures are run roughly the same between the two trucks.
My AI tells me that the force applied by the torque of the engine, through the wheel and tire, to the road surface is a function of wheel/tire radius. And increasing that radius by 10% (roughly the amount of increase when going from 18 to 20 inch wheel) will reduce the applied force by about 10% as well. So, increasing wheel radius will decrease towing performance.
Depends on what size tire you put on it. Just because the wheel is bigger doesn’t mean the tire is.
Your AI doesn't tell you all the info you need. It is a function of the overall radius, not just the wheel radius. If OP is getting a Tremor, which comes with 35" tires and 18 inch wheels, and gets 20" wheels and 35" tires for that size wheel, it won't change the force applied to the road surface. What MAY affect towing performance in this instance would be the weight rating of the tire and wheel - if the weight rating of either goes down from factory, then he will lose towing capability. If it doesn't, then he's fine to proceed as normal.
Did your AI also have a disclaimer that it may not know what it was talking about?
It has nothing to do with WHEEL radius, only TIRE radius. As long at the tire radius is the same it doesn't matter if the rim is 15" or 24".
This AI answer is absolutely correct…………unless the OP goes and puts tires on those new wheels, then it’s all about the tire size, not the wheel size.
I am big fan of the other AI, Actual Intelligence.
It’s like going to a really nice public library that’s known for quickly providing answers you’re looking for, with one catch: the answers sound authoritative & are provided in a formal slick & polished way, but at least 50% of the info is pure hallucination BS. It’s like going to Earl Schieb for stock tips, are they gonna Wash away the next time it rains?
So what if you increase the wheel size and decrease the sidewall height? It just doesn't account for the tire, so it's not right. Common sense prevails.
The physics are correct, yes. But the AI answer is wrong, in that it states that JUST increasing the wheel (metal part of the assembly) diameter alters the force. That is incorrect. The major diameter of the TIRE/WHEEL ASSEMBLY is what drives that calculation, NOT the diameter of the wheel. If you have a 35" tire, for instance, it doesn't matter if it is on a 15 inch rim or a 24 inch rim or anything in between, the force applied to the road REMAINS THE SAME.
The shop that posted the article you linked to 'dumbed it down' too far - a WHEEL is not a TIRE. The TIRE is what contacts the road, the WHEEL is also known as the RIM - what the tire gets mounted on. Tire and wheel are two different terms that shouldn't be used interchangeably. If that is a reputable shop, they should know that and make the difference clear.
So I will re-state that the AI answer provided above is INCORRECT, it doesn't matter what WHEEL SIZE you have, it matters what TIRE SIZE you have.
