Looking at buying a clean 2015 f250 6.7. Truck is a good deal but I have zero experience with the new Ford trucks. Truck isnt running and im thinking major fuel system issue, codes are p0263,p0269, p02d6 p02d4.
stay away or worth the risk?
The codes indicate problems with the injectors for cylinders 1,3,5, and 6. Unless you can get it for a real good price it may be expensive to fix. Does it crank and what are the fuel pressures while cranking? There was a TSB 16-0064 that lists all of your codes, but you need the engine to run to check it further.
you don’t know if the injector codes are a result of a short cut fuel system repair…instead of replacement ng everything that should be replaced …they may of cleaned and reused …or even didn’t realize the entire proper procedure…particle got the injectors and the injectors are done.
