Engine Stalling
Old Nov 17, 2025 | 11:06 AM
a.goudey's Avatar
a.goudey
Trailering
Engine Stalling
1997 F250hd 460
I have a mystery. Engine stalls while cruising and occasionally won't start when cold. When cruising it is as if a switch was thrown and truck coasts to a standstill. After about twenty minutes it will start again. After that it doesn't happen again until the next run to town. I have changed plugs, wires, cap, rotor, coil and lastly the ignition module. It usually happens around the fifteen kilometer area. Since replacing the ignition module it still happens, but manages to recover after a couple seconds and the drive continues. Would this possibly be a sensor from another component sending a wrong signal just as the engines fully warms up?
Old Nov 17, 2025 | 11:50 AM
Split rims's Avatar
Split rims
Wrong forum.
Old Nov 17, 2025 | 12:37 PM
a.goudey's Avatar
a.goudey
Trailering
Newbie. Which forum is the correct one? Thanx
Old Nov 17, 2025 | 07:31 PM
jimzpsd's Avatar
jimzpsd
This would be your best bet.
https://www.ford-trucks.com/forums/forum28/
Old Nov 17, 2025 | 10:17 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Update: @a.goudey has started a thread for this over in 1987 - 1996 F150 & Larger F-Series Trucks. Feel free to swing by over there if you have any ideas!
melchor1106
36
Dec 28, 2022 02:36 PM
bulldogcountry1
Oct 19, 2014 08:53 PM
Aerik
Sep 28, 2009 03:57 PM
gilllawn
Jan 25, 2009 03:51 PM
