2012 6.7L Code P2073
Old Nov 16, 2025 | 03:07 PM
FSFT's Avatar
FSFT
Trailering
Apologies- Meant to post this in the 1999-2016 forum.
Correlation problem between the Manifold Absolute Pressure (MAP) sensor, Mass Air Flow (MAF) sensor, and the Throttle Position Sensor (TPS)
I have removed, cleaned and reinstalled MAF sensor. Reset code and now its back after 30 miles. I guess I should clean the MAP as well.
Any other areas? The throttle body is clean, nothing obvious there.
Appreciate any ideas.
Old Nov 16, 2025 | 03:51 PM
wcbcruzer's Avatar
wcbcruzer
Could still be a bad sensor. Cleaning them is a start, but it could have an internal malfunction. If no work was recently done to the engine, I doubt there's a vacuum/air leak, but that would be my next move if sensors are ok.
Old Nov 17, 2025 | 12:58 PM
Trash Hauler's Avatar
Trash Hauler
If cleaning the MAP sensor doesn’t fix the problem, it may be worth resetting the MAF Adaptation. Using FORScan Lite for Android, under service tab, PCM section, reset MAF Sensor Adaptation.
There is also TSB 22-2115 that may be applicable for you.
https://www.tsbsearch.com/Ford/22-2115
I have the 2013 shop manual and can look through it for the troubleshooting guide if you would like.
Bob
cj45lc
Sep 18, 2022 09:40 PM
xaos
Jun 6, 2022 05:49 AM
Pcompton
28
Feb 7, 2022 04:05 PM
okstate734
Computer Chips & Tuners
Oct 13, 2009 07:43 AM
fixingbus
1983 - 2012 Ranger & B-Series
Mar 28, 2008 06:05 AM
