Spring experts; advice needed !
Old Nov 12, 2025 | 07:32 AM
MOAK's Avatar
MOAK
Way back when if one wanted to increase spring rate you just went to any spring shop and added the appropriate leaves for what you were doing. In our case-F-250 farm trucks. They road like a rock empty, but didn’t sag with a load of hay, grain or livestock. Today? I have a constant load of 2,200 lbs with a 4WC pop up bolted to an aluminum flatbed. Carli can increase the constant load by 2,000 lbs. The cost? Over 3k, which is nuts. Deaver builds the spring sets for Carli using stock 250 or 350 springs, then adds leaves. Deaver is in metro LA, yuck! Where are any old school spring shops that can do this? What leaves ( # number and brand ) and how many leaves?
Old Nov 12, 2025 | 08:49 AM
99powerstrokedF250's Avatar
99powerstrokedF250
A competent spring shop can get you anything you want, likely without adding leaves to the pack.
My suggestion would be to go to whoever builds the spring packs for your local DOT - they might be a drive away, but they can do the work. When I broke a spring on my '99 F250 (truck wasn't even loaded when it happened), they were able to build me a brand new set of springs, installed, for $150/side. Now, this was 15 years ago, so I'm sure prices have gone up - but those spring shops are still in business somewhere.
Old Nov 12, 2025 | 10:17 AM
JW350's Avatar
JW350
Atlas Suspension may be another option for you.
https://www.atlassuspension.com/
Old Nov 12, 2025 | 11:19 AM
6.2caribou's Avatar
6.2caribou
I watch a lot of off-road recovery videos. Moab Motorsports (Rory Irish...TrailMater) and a hew others speak quite favorably of a shop in Grand Junction, CO. I'm pretty sure that it Alcan.
https://www.alcanspring.com/
Old Nov 12, 2025 | 01:31 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I have a set of springs out of a 2004 F250 that I plan on robbing a leaf out of and putting in my ‘24. The sag is ridiculous Ford!
We used to have an awesome spring and suspension shop here in town, but they closed up years ago. I used to get them to make me all my U-bolts and top plates for my projects.
Old Nov 12, 2025 | 04:04 PM
MOAK's Avatar
MOAK
yes, that’s the problem, decades ago we had a great spring shop near where I lived. Gone- most of them are gone.
Old Nov 12, 2025 | 06:53 PM
350Recon's Avatar
350Recon
Hellwig Helper Springs
I am going to order these.
I called them up and they said to order them from a local dealer so I can be put on the order list.
Jefe4x4 put them on his 2020 F350 but the springs are longer on the 2023 and newer as I was told by Hellwig.
Jefe4x4 Hellwig springs.
Jefe4x4 review here
refur
Apr 4, 2024 04:11 PM
willymakeit
Oct 1, 2023 08:59 PM
arazu
Dec 21, 2022 05:41 PM
carchub
Dec 2, 2020 05:28 PM
77hiboyboy
17
Jun 30, 2008 02:46 PM
