1978 - 1996 Big Bronco
Throttle body difference 351W
Old Nov 10, 2025 | 08:56 PM
gov2mod's Avatar
gov2mod
1991 Bronco with 351W. What is the difference between the original throttle body F1TZ9E926Gon my 91 Bronco with 351w and the later F6TE-RA throttle body?
Old Nov 10, 2025 | 09:17 PM
Conanski's Avatar
Conanski
The coolant line fittings changed shape and it went from 2 evap connections to one.
Old Nov 10, 2025 | 09:30 PM
gov2mod's Avatar
gov2mod
Thanks. So if I replace the one on my 91 Bronco it shouldn't matter which one I get, correct?
Old Nov 11, 2025 | 12:49 PM
torq'ta 5 8's Avatar
torq'ta 5 8
If you get the single EVAP throttle body, plug 1 line on your EVAP.
Old Nov 11, 2025 | 11:33 PM
Conanski's Avatar
Conanski
No it won't matter, functionally they are the same and fwiw I believe the 5.0 use the exact same TB too.
Old Nov 15, 2025 | 06:29 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Conanski
…I believe the 5.0 use the exact same TB too.
Yes. Both engines use the same throttle body. I used to pick up spares when at the junkyard since the BBK t/b is expensive junk.
Muskyhunter715
Apr 4, 2022 07:39 PM
HollywoodF-150
Mar 29, 2005 10:03 PM
offroad_guru
Oct 10, 2004 01:18 AM
RippedBronco
May 9, 2003 02:16 AM
