Cab Replace
Old Nov 9, 2025 | 08:32 PM
mtnxtreme's Avatar
mtnxtreme
Cab Replace
Replacing a damaged cab on my 17 Super duty, bare cab , how do I attach my vin to that cab? All I have is a bill of sale.
Old Nov 9, 2025 | 09:16 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Cut the VIN plate off the old cab, weld to new cab.
Old Nov 10, 2025 | 02:21 AM
speakerfritz's Avatar
speakerfritz
Old Nov 10, 2025 | 04:29 AM
charlie g's Avatar
charlie g
FTE Community Team
take note that the vin is also stamped into the body in several other spots that are unseen to people not knowing where they are,
swapping the cab your going to be dealing with DMV retitling the truck as a rebuilt vehicle, in NY it's like what i had to go though in NJ not fun
Old Nov 10, 2025 | 06:44 AM
mtnxtreme's Avatar
mtnxtreme
its a 17 it’s aluminum and the vin is a sticker behind windshield and on the door post
Old Nov 10, 2025 | 06:46 AM
HorizontalHunter's Avatar
HorizontalHunter
Originally Posted by speakerfritz
This.
If you don’t do it right it will be a nightmare to sell or cross the border with.
Bob
Old Nov 10, 2025 | 06:49 AM
mtnxtreme's Avatar
mtnxtreme
I hear you I have dealt with NY with a salvage title before. But I mean you should be able to replace a cab ?! I also have the option of doing it in Florida. But either way I still need my correct titled vin numbers on this new cab as I’m gonna junk the old cab.
Old Nov 10, 2025 | 08:58 AM
jimzpsd's Avatar
jimzpsd
Do the swap the best you can and enjoy your new ride.......don't worry about it, make it look legit as I doubt any one would be "investigating"
Old Nov 10, 2025 | 09:45 AM
Mike Bartlett's Avatar
Mike Bartlett
I would start with your states DMV being each state has different rules that should be followed.
Good luck,
Mike
Old Nov 10, 2025 | 10:19 AM
longhaultransport's Avatar
longhaultransport
Unless someone complains about it I wouldn't sweat it.
It will most likely never be an issue. Cross that bridge when and if it ever comes up.
Old Nov 10, 2025 | 05:09 PM
mtnxtreme's Avatar
mtnxtreme
Problem is that it’s a salvage truck so will need dmv inspection I’m wondering if it will be an issue ?
Old Nov 10, 2025 | 05:16 PM
Joe T's Avatar
Joe T
I would contact a Ford parts department or body shop.
Old Nov 10, 2025 | 05:53 PM
HorizontalHunter
Lin my state the DMV will make your life miserable if you don’t follow the proper procedures and have you paperwork (receipts) in order showing where every part came from. Every state is different but you need to see what your state requires. A body shop that does salvage cars could probably point you in the right direction but your best information will come from the source; likely the correct division of the DMV.
Bob
Old Nov 10, 2025 | 07:45 PM
Old and soft's Avatar
Old and soft
I have done several special construction titles in MO. The highway patrol knows what for and where to look for descrepancy. That is their job, and they seem to luv their job. In MO, the title follows the vin. A bill of sale only would open a can of worms, the big slimy kind that bite you when you try to put em on a hook. It can be done here, but involves a judge's signature among other things.
Old Nov 11, 2025 | 11:02 AM
mtnxtreme's Avatar
mtnxtreme
Is there no way to just replace a cab like replacing a fender ? I’m wanting to use my vin on it, and have it inspected and using my legit repair title, I don’t know maybe I’m thinking wrong, but I see the cab as an “auto part”, like a bed, door, hood etc. I see several cabs for sale on eBay by junkyards, they all state they are required by law to retain the title of the cab. So how would someone use that cab without putting their vin on it, and if they couldn’t, why even purchase that cab ?! And wouldn’t you think they would rather see you use a solid cab than repaired one to repair that truck ?
