Sponsored by: Real Truck
Puck System "Flush" Covers?
Old Nov 7, 2025 | 10:30 AM
Tony Berry's Avatar
Tony Berry
I did several searches, but didn't find anything related.
Is there a puck cover set for the 2011 Ford F-350 dually that will allow things to be slid into the bed? I commonly bring empty pallets to Lowe's to stack stuff on and use my CTL to unload the loaded pallet when I get home. Sliding the pallet into the bed is ALWAYS a major PITA because of the puck hole covers. Doesn't someone make a cover that would sit below the ribs on the floor of the bed so things would slide above them without snagging on them?
I even tried AI queries, but they weren't helpful. Only linking to OEM, or OEM-style, covers.
Thanks!
Old Nov 7, 2025 | 11:27 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Going to need to ask you what year your truck is, because my FIL had a '22 with the puck system, and I have a '25 with the puck system, and the covers were/are flush with the ribs in the floor (both trucks had spray-in bedliners). Maybe an older model they sat proud?
Old Nov 7, 2025 | 12:05 PM
2005_HARLEY_F250's Avatar
2005_HARLEY_F250
4wd Low
BC3Z-99000A35-A
some sites will say 2011-2016 but this fit my 2017 w/spray in bedliner. Comes with the caps and the rings that cover the gap between the pucks and bed.
Old Nov 7, 2025 | 12:18 PM
Tony Berry's Avatar
Tony Berry
[post removed]
Old Nov 7, 2025 | 12:21 PM
Tony Berry's Avatar
Tony Berry
My truck is a 2011 F-350 dually. It does have a spray-in liner. I can try to take a picture to show the issue.
Since it is typically parked under a cover, I just leave the covers off. Tired of them either getting smashed/deformed or just popping off to be lost with Interstate driving.
Old Nov 7, 2025 | 12:24 PM
Phillbo's Avatar
Phillbo
So that's what those things are. I found them in a bag under my seat when I bought the truck. I think they are still there.... Why do you need to cover them?
Old Nov 7, 2025 | 12:58 PM
Tony Berry's Avatar
Tony Berry
Your salesman failed you.
To keep debris and excessive moisture from getting into those "intimate" spaces.
Nevets Negah
All Things Towing
28
Oct 18, 2023 04:59 AM
msp3164
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Aug 4, 2023 02:57 PM
Christian's1988Ford
Feb 23, 2017 06:27 AM
nivram
Aftermarket Products
Jun 13, 2007 03:25 PM
