Rough Idle
Old Nov 10, 2025 | 09:05 AM
woody18's Avatar
woody18
Thanks! I’ll probably order an IPR then. I’ll inspect my lines as well, could be I didn’t do a great job when installing the driven diesel in tank filter delete.
she’s a 4x4 SRW CCSB Lariat
Old Nov 11, 2025 | 12:18 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Originally Posted by BWST
Looking at those 2 WOT files, it does look like ICP is lower than normal, but the PCM is adding PW, and the rig is performing well. You could change out the IPR and see if your rough idle smooths out. Checking for fuel aeration is another possible cause - usually from the fuel line connections between the tank and frame rail pump ( the suck side).
I measured your 20-60mph time on WOT 1, and it's 7.6 seconds, good for an empty truck on a stock tune. What is your truck's cab and bed size? Wanted to get an idea of the weight.
I really appreciate your ability and willingness to share what you glean from these files.
I learn something new every time.
Gonna buy you a beer some day.
Old Nov 22, 2025 | 05:42 AM
woody18's Avatar
woody18
New IPR fixed the stumble at idle or at least it feels like it. Need to gather some data on my fore scan to see if the data reflects what my butt dyno tells me. I’ll post the CSV whenever I get one! Thanks for the help troubleshooting.
Old Nov 22, 2025 | 09:16 AM
Dan V's Avatar
Dan V
I had noticed a barely noticeable rhythmic variation at idle on mine. I really just thought is was the 400k miles catching up to it. But then towing the horse trailer through Des Moines...the HPOP failed, leaving me stranded. I had installed a new IPR 3 years ago.
Old Nov 22, 2025 | 10:58 PM
woody18's Avatar
woody18
Don’t put that evil on me Ricky Bobby
Old Nov 24, 2025 | 08:01 AM
oharal's Avatar
oharal
Looking forward to that data!
Old Nov 25, 2025 | 07:21 PM
woody18's Avatar
woody18
Here’s a drive with some pretty mixed variations of drive style. Should be some close to WOT pulls.
File Type: csv
Old Nov 26, 2025 | 07:08 PM
woody18's Avatar
woody18
More data! Mostly all highway.
File Type: csv
Old Dec 12, 2025 | 08:40 AM
woody18's Avatar
woody18
Annnnnd the rough idle is back. Now it will clear up when ICP is unplugged. I’m going to double check the wiring of it because it’s new as of a year ago.
Old Dec 14, 2025 | 01:44 AM
aawlberninf350
It's a Van Gogh
If it clears up when the ICP is unplugged that's a good sign the wiring is fine, but the ICP is not.
Any oil on the connector? If so clean it up with some spray contact cleaner and reuse.
Then get a new ICP from a trusted source like Riff Raff or Diesel O Rings.
Old Jan 25, 2026 | 05:29 PM
woody18's Avatar
woody18
New ICP from Diesel O Rings. No real change. Truck performed well on 3400 mile road trip up to altitude in Colorado. Had extreme difficulty starting despite new Mitsubishi stock style starter, new GPR and New battery Cables. Here’s some data at altitude and recently with a load. Thinking injectors may just be worn out as best I can tell they are originals.
File Type: csv
Old Jan 25, 2026 | 05:30 PM
woody18's Avatar
woody18
Loaded Drive Data
File Type: csv
Old Jan 26, 2026 | 12:33 PM
  #28
RacinJasonWV's Avatar
RacinJasonWV
Been following along but haven’t had anything helpful to offer.
Nice Mustang in your profile photo!
Trouble starting could be GPR related. You can try crossing the large terminals for 30 seconds (more or less) immediately before cranking to see if it helps.
Otherwise 5w-40 helped mine start more quickly. Not sure how that may affect your wandering idle though.
Old Jan 27, 2026 | 07:52 AM
  #29
woody18's Avatar
woody18
Thanks! It’s a ‘22 GT500, my uncles but I get to drive it. Pushing about 900 to the wheels as we increased the blower size and it’s running on E85. Been having issues with it hooking up, all that fancy technology doesn’t like the additional power and the big slicks.
I currently am running 5W-40 and made the switch for that very reason, I will check the GPR again but now that I’ve done some more searching I think maybe I was simply asking too much of the truck when it had trouble starting. It was 0 degrees ambient temp at 9000’ elevation. This morning it was 26 deg here at sea level at home and it cranked absolutely no problem.
Old Jan 27, 2026 | 08:10 AM
  #30
z31freakify's Avatar
z31freakify
Get a quart of 2 stroke oil, add some 2 stroke oil directly into the fuel bowl maybe a quarter of the way and the rest in the fuel tank, that helped my 00 a bit when it it had old injectors. Could also be worn out injectors causing hard cold starts and smoke, you could probably prolong them a little more if short on dinero by shimming them.
Also you mentioned oil loss, does the truck have serious blow by? Has the injector O rings ever been replaced? IMO like I previously mentioned you might want to at least get new injector O rings and shim them in the bench and see if the oil consumption goes down and your hard hot starts goes away.
