is it a clutch or tranny problem?
Old 12-08-2003, 03:03 PM
carl danes's Avatar
carl danes
carl danes is offline
Question is it a clutch or tranny problem?
HELP! ADVICE IS NEEDED
I have a 1994 4x4 F150 with a manual tranny and about 65K original miles.
Here's the question; When I let the clutch out in second or third gear and push on the accelarator the engine RPMs pick up but the speed doesn't increase for about 2 or 3 seconds, then it kicks in.
It's as if the clutch is slow to release (just my uneducated guess).
The fluid level is good.
Any ideas?
Old 12-08-2003, 04:02 PM
mcanik's Avatar
mcanik
mcanik is offline
Sounds like the clutch slipping
Old 12-08-2003, 06:27 PM
95BlackF150's Avatar
95BlackF150
95BlackF150 is offline
yeah could have some fluid on the disc or it could be just worn out surely ford clutches last longer than 65K miles
Old 12-08-2003, 08:13 PM
Tim Ervin's Avatar
Tim Ervin
Tim Ervin is offline
Most clutches go farther but I've seen them fail a lot quicker if somebody overloaded the truck or other driving mistakes. I'd suspect clutch disc/pressure plate needs replaced. Good time for clutch release bearing/pilot bearing/slave cylinder if you don't enjoy pulling the trans. It seems I have to go in every so often for rear main seal or something already mentioned. 2wd don't bother me but I hate dropping the 4x4 trans.
Old 12-10-2003, 06:27 AM
mr clutch's Avatar
mr clutch
mr clutch is offline
Your clutch is slipping whether from contamination or wear. Either way you will need to replace the clutch and slave cyl. Give me a call if you need any help. 888-462-2739
1959_f100
03-11-2012 04:38 PM
bleeds blue
10-19-2009 11:43 AM
dominof-250
04-04-2004 12:09 PM
cutlas1972
09-24-2003 06:31 AM
captbly
04-06-2001 11:15 AM
Quick Reply: is it a clutch or tranny problem?
