Cowl and hood
Old Nov 2, 2025 | 03:12 PM
1988 ford f150 5.0's Avatar
1988 ford f150 5.0
4wd Low
Cowl and hood
So I took my hood off without marking it (which I didn’t know I had to at the time) and took the cowl off to replace my windshield wiper motor and put it back on and the cowl won’t go far enough back for me to adjust and Aline the hood so it closes correctly (1988 for f150 bricknose)
Old Nov 2, 2025 | 06:42 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Why would you have assumed that? The hood can be moved forward, backward and side to side. Have you tightened the cowl screws or is it still loose?
Old Nov 3, 2025 | 05:36 AM
manicmechanic007's Avatar
manicmechanic007
Do you have your cowl panel back far enough?
The rear of the cowl sits "under" the lower windshield chrome molding
It can also be adjusted fore and aft
Old Nov 3, 2025 | 03:17 PM
1988 ford f150 5.0
4wd Low
I’ve tighten the cowl down as far back as I can get it . Do I need to take the chrome off the windshield and clean all the dirt and sticks and leaves from under that ?
Old Nov 3, 2025 | 04:31 PM
My4Fordtrucks
Maybe? It should slide back in place and then you install the screws. If there was gap between the two then you need to get it under the chrome as was mentioned in post #3
kr98664
Jan 13, 2022 08:07 AM
F250_
13
May 21, 2007 10:57 PM
inline6'er
Apr 28, 2003 08:07 AM
