Oil & Lubrication
oil additives
Old Dec 8, 2003 | 01:50 PM
da cubs's Avatar
da cubs
oil additives
Does products like Slick50 or Dura Lube actually help your engine, or are they a bunch of crap????
Thanks,
Mike
Old Dec 8, 2003 | 03:07 PM
Andysutt's Avatar
Andysutt
Bunch of crap, They have been sued by people and proven to not work
Old Dec 8, 2003 | 04:22 PM
76390FE's Avatar
76390FE
the only stuff that I have found to work is seafoam. But it won't actually fix anything in the engine...just clean things out.
Old Dec 8, 2003 | 04:24 PM
Andysutt's Avatar
Andysutt
If you think an additive will actually fix something, then your stupid anyways
It may "fix" bad gas mileage
but it wont help bearings and such if they are worn out
and seafoam works good
Old Dec 8, 2003 | 04:28 PM
76390FE's Avatar
76390FE
Nicely said Andysutt
Old Dec 8, 2003 | 04:29 PM
Andysutt's Avatar
Andysutt
I wasn't calling anyone in this thread stupid. I was just saying
And thanks 76 390FE
Old Dec 8, 2003 | 05:38 PM
jim henderson's Avatar
jim henderson
There is a post on this website that talks about additives. I think it is called "snake oil".
In short most additives have been shown to have little or no benefit, in a reasonably healthy engine. Some have been shown to actually cause harm. As long as you use a good oil that meets API and SAE spec for your engine and change regularly, you don't need additives.
Differnt story for an engine that is in bad shape. Then an additive can be thought of as a bandaid to get you thru until you can do something permanent to fix the problem.
Good Luck,
Jim Henderson
Old Dec 8, 2003 | 05:39 PM
Andysutt's Avatar
Andysutt
Good wording there Jim
"bandaid" is the word for it
