1997 Explorer 5.0 Losing ATF with P0402 code
Old Oct 28, 2025 | 12:18 PM
MeanGene427's Avatar
MeanGene427
1997 Explorer, 5.0 auto. It has been slowly losing ATF, but has no external leaks- I can parking it every day in the same spot, it has no external leaks anywhere. Also getting a P0402 code- EGR was replaced a couple years ago. Can the two issues be related? As in can it somehow be drawing ATF through the EGR valve? Scanner won't give info past the code as to what is causing the problem with the EGR. TIA!
Old Oct 28, 2025 | 12:38 PM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
If there is no evidence of leaks, it is probably pushing it into the transfer case. Pull the fill plug and see if fluid comes out. It could also be entering the cooling system through a ruptured cooler but then you'd more than likely have coolant in the trans and things would be real bad. EGR has nothing to do with the transmission. The P0402 could be another bad EGR valve but I suspect the DPFE sensor or the little tubes that go to it have gone bad.
-Dan F
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Old Oct 28, 2025 | 01:38 PM
MeanGene427
It's 2WD, and no oil in coolant. Radiator was replaced a couple years ago. Checking the EGR system now
Old Oct 30, 2025 | 01:18 PM
shorod's Avatar
shorod
Do you have a hand vacuum pump that you can use to confirm the mechanical functionality of the EGR, as well as to measure for vacuum to the EGR valve off idle?
-Rod
sjwoody
May 3, 2005 05:29 PM
JTD1972
May 23, 2004 12:05 AM
