Is this my DMF going out?
Old Oct 27, 2025 | 09:59 AM
jack345's Avatar
jack345
4wd High
Hi Y'all,
I have a 1991 F-250 7.3 IDI 4WD ZF5
I recently noticed a shaking coming through my shifter when I depress the clutch in high gear. At first I thought this must be my transmission or motor mounts, but my engine and transmission don't seem to be moving at all when hold the break down while giving it some gas, and no amount of prying of them seems to cause movement.
The video shows this happening when I put the clutch in in 5th gear (the back of the truck is on jack stands) I'm concerned this is an early sign of my DMF going out, since I can't find any other logical reason for the shake. Anyone have any ideas about this? I've never worked on a vehicle with a DMF before and what I've read about them cracking bellhousing has me worried.
I need to do my ball joints this week, and it would be a pretty big blow if the DMF went out not long after I put that money and work into it. I'm trying to figure out if a new flywheel/clutch is going to be needed soon as well, or if this shake is something I don't really need to be too concerned about.
Thanks so much taking the time the read this. Any replies are appreciated!
Jackson
File Type: mp4
Old Oct 27, 2025 | 11:27 AM
knottyrope's Avatar
knottyrope
pull the inspetion plate off and pry the plate
if it moves, then you know what it is
Shifter moving like that could be input shaft or pocket bearing worn if DMF is ok
Old Oct 27, 2025 | 03:35 PM
tjc transport's Avatar
tjc transport
i ain't rite
dmf was a good idea on paper, but a bad idea in the real world. after a few years of abuse, they fall apart.
i had one that fell out of the truck in 4 or 5 pieces after the trans was removed.
Old Oct 28, 2025 | 10:01 AM
jack345's Avatar
jack345
4wd High
Hey thanks for much for your replies. I didn't realize I could just pull off the inspection plate.
Knottyrope, I know you said "it if moves, then you know what it is"
I attached a video because there is a little bit of movement with the prybar, but it wants to come right back and feels pretty solidly on there. Is this the kind of movement your talking about?
File Type: mov
Old Oct 29, 2025 | 12:40 PM
knottyrope's Avatar
knottyrope
you are moving the flex plate part
Now try to move back n forth the pressure plate while in N and parking brake on
See if it moves too much like in this thread
https://www.ford-trucks.com/forums/9...-complete.html
Old Oct 29, 2025 | 09:02 PM
jack345's Avatar
jack345
4wd High
Oh, I see what you mean now.
Looks like I have a whole lot of slop!
Thanks for your time and patience in explaining this to me
File Type: mov
Old Oct 30, 2025 | 01:36 PM
knottyrope's Avatar
knottyrope
You are welcome and thanks for posting your vids to help others.
Make sure your input shaft on the trans has no play when you remove it
DMF can ruin that bearing and the pocket bearing goes with it
not bad to rebuild, i have done it before in my garage on a small table
Natha2
Sep 4, 2024 09:18 AM
Michael Gregory
Aug 8, 2024 08:59 PM
89nolaf250
Jun 28, 2010 10:04 AM
agryphon
1983 - 2012 Ranger & B-Series
Feb 21, 2007 09:45 PM
AaronW
17
Aug 16, 2002 11:24 AM
