Where does this go ????
Old Oct 23, 2025 | 04:20 PM
Phil527's Avatar
Phil527
Any ideas where this goes? This will drive me nuts all winter, one part I did not bag/label when removing - some sort of heat shield part off of a 86 F250 460- probably not super critical but I would like to find out where it lived.
Short summary is truck failed inspection late 2018 because cab corners and rockers rusted out to where seat belts were not anchored. Sat a while then I started with some repair parts for floor/cab corner/rockers and project soon migrated to pulling the bed, scaling and epoxy painted frame, new bed sides, fenders, pristine donor doors from a u pull, pulled engine to change oil pan rear seal and clutch, new brake lines, etc.etc. I have all the body work done and sealed with epoxy primer and was organizing to get set up to paint everything in the spring and forgot about this piece. I believe I removed it when pulling the engine, thought it might be from around the starter but I can't find any likely places where it seems to fit.
Old Oct 23, 2025 | 06:14 PM
Franklin2's Avatar
Franklin2
Look around the front of the engine and see if it is a belt guard of some sort. That is a guess.
Old Oct 23, 2025 | 07:34 PM
kr98664's Avatar
kr98664
Heat shield for a motor mount? My 351W has something similar on the driver's side because the exhaust pipe is fairly close. Nothing on the passenger's side as that exhaust pipe is further away.
Does this look similar? Appears to be a repro for a Ford big block:
https://www.ebay.com/itm/285804492500
Image from eBay
Image from eBay
Old Oct 24, 2025 | 07:58 AM
Franklin2's Avatar
Franklin2
Here are some 429/460 motor mount shields on ebay. https://www.ebay.com/itm/285804492500
Old Oct 24, 2025 | 10:29 AM
Phil527's Avatar
Phil527
460 Motor mount heat shield
That's it!!!
Thanks- I was not thinking about the engine mounts. I searched around for motor mount heat shields and found a few posts with pics that has it on the driver side motor mount. Now I can sleep at night
ternus
52
Jan 7, 2026 02:02 PM
Big Horn 2
Aug 26, 2025 02:57 PM
NorthwestNick
Jan 28, 2023 03:07 PM
markfuga
65
Oct 16, 2022 04:55 PM
BigBlueRanger1977
Sep 12, 2022 06:35 PM
