Zf5
Old Oct 23, 2025 | 12:49 PM
06f35097f350's Avatar
06f35097f350
Zf5
It's time to change the transmission oil in my ZF5-47. I have a gallon of synthetic Castrol Transmax universal. It says it is suitable for applications that call for Mercon/MerconvV. Can anyone verify that it will be okay to run this? I think I have run it in my ZF6 in the past without issue but I honestly can't remember for sure.
Old Oct 23, 2025 | 01:03 PM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
I would say it's fine if it meets the specs. I know people run all sorts of stuff in these things and they're of the age and probably mileage that a thicker more lubricating fluid would do them some good. Red Line MT90 or MTL some people use with positive outcomes. ATF is far better as a hydraulic fluid than it is as an oil. I wouldn't run straight up gear oil but something better than red water such as an actual manual trans fluid would be beneficial in my mind.
-Dan F
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Old Oct 23, 2025 | 07:26 PM
aquartlow's Avatar
aquartlow
I run 15w-40 full synthetic diesel oil in my ZF5 and ZF6 speeds. The 5 speed is behind a 472 BBF and the 6 speed is behind my 7.3 PSD. Motor oil is much better at lubricating and greatly helped quiet down both transmissions. The 6 speed has been on motor oil for 250K miles(has 420K on both it and the 7.3) now and the 5 speed was rebuilt prior to me purchasing it-Fred Jones rebuild no less, it has just been installed in my late son's '95 F150..
Old Oct 23, 2025 | 07:56 PM
TobyB's Avatar
TobyB
The only down side to motor oil in a transmission designed for gear oil/ atf
is that motor oil tries to keep solids in suspension so the active filter can filter
them out,
and gearbox fluids let them precipitate so that they don't stay in circulation
in unfiltered oil.
I'm sure it doesn't matter that much, but the concept is worth mentioning.
I'm overdue for a change on mine...
t
Old Oct 23, 2025 | 08:26 PM
06f35097f350
That' is something I hadn't considered. I run Rotella T6 in both my 460 and my Powerstroke diesel and I have plenty on hand. That is something I am going to have to give some thought to. Thanks for the suggestion.
Old Oct 23, 2025 | 09:13 PM
aquartlow's Avatar
aquartlow
You are certainly welcome. I never liked the "gear rollover" noise my ZF6 had, even at 150K. I asked a buddy of mine who owns a 4x4 driveline shop near me about using motor oil, he said if the low temp oil viscosity is close there wouldn't be an oiling/lubricating issue at low temps, but the 15W-40 motor oil at operating temp has much more viscosity and returns a less noisy transmission and it's internals are better lubricated. It actually shifts better as well and we all know a ZF trans isn't anywhere near a buttery smooth shifting trans. Now I do live in central Florida, so low temp(under 20 degrees F) shifting and/or lubrication issues haven't been a big concern-The ZF6 has an oil pump and external cooler and I've had ZERO issues so far. If you do live in colder climates, using 5w-40 may be a great option. Good luck with whatever lubrication you choose.
Old Oct 24, 2025 | 08:49 AM
Hit Man X's Avatar
Hit Man X
My S5-47 in the dually is fairly fresh with about 30k since I built it. It runs Redline D4, I fill from the top and add one extra quart. No problems, rare earth magnets on the PTO covers inside. I really would like some sort of filter for one, yet never could find one.
I run half MTL and half MT90 from RL in my Getrag 265/6. It specs ATF or a 75/90 GL4 oil, shifts excellent like that. GL5s is corrosive to the syncro rings as I recollect so no rear axle oil.
dieselsubmariner
24
Sep 21, 2014 12:47 AM
papp
Dec 31, 2010 11:14 AM
FARM69
Jan 4, 2007 08:19 PM
Boy Woofer
Jan 27, 2005 06:52 AM
HoseDog
Oct 14, 2004 02:44 PM
