400 Compression numbers and options
Old Oct 18, 2025 | 08:24 PM
88grandmarquis's Avatar
88grandmarquis
1978 F-150 400, 4-speed, 4x4. Starts and runs decent, but produces a small amount of grey/black smoke. Previous owner stated engine was from a '76 LTD. I've had this truck for 8 years, and never got around to fixing it up. It is run a few times a year just to move it around the yard. All spark plugs looked about the same: good gap, but black with fuel smell.
Compression test numbers:
1: 138
2: 138
3: 119
4: 124
5: 40
6: 100
7: 124
8: 120
I did squirt oil into 3 and 5 with no change in compression. I'd like to fix up this 4x4 truck at some point since it is the kind of truck I grew up with. I also have a 1979 F-150 4x2 C6 with a 400 that is bored .030. No info on who did the work, or when that motor was built. I've installed a Comp Cams kit and a lot of new stuff on that engine. However, I'm trying to sell the 4x2 since I completely lost interest in it (Honestly, I never should have bought it). Neither truck is road worthy at this time. I could steal a lot of new parts off of the 4x2 and use them on the 4x4, including the engine (after switching over the necessary 4x4 parts).
Curious what you guys think of those numbers. Were the heads on truck and car 400's the same?
Old Oct 19, 2025 | 09:22 AM
Destroked 450's Avatar
Destroked 450
You definitely have a problem with #5 cylinder
Old Oct 19, 2025 | 09:46 PM
tbear853's Avatar
tbear853
Squirted oil in and seeing no change in compression reads like might be some burnt valves.
Old Oct 19, 2025 | 09:57 PM
manicmechanic007's Avatar
manicmechanic007
Right, IMO you have burnt valves in cylinder 5, and leaking valves in 6, possibly a head gasket issue as well between those 2 cylinders
Old Oct 20, 2025 | 08:30 PM
88grandmarquis
Thanks for the feedback. I didn't think about burnt valves.
peakster
Sep 14, 2014 09:58 AM
damac
Mar 9, 2010 04:05 AM
Colo79Ford
Sep 17, 2008 06:36 PM
Burg460
Feb 28, 2008 03:01 AM
Ranger Gord
Mar 11, 2007 12:46 PM
