Brake issues
Old Oct 17, 2025 | 11:42 AM
Yipe's Avatar
Yipe
3rd Gear
Brake issues
Have a 84 F250
Brake pedal is very soft. I notice it does close the pads but have to keep pressing the pedal to the floor and hold them hard to make sure the truck stops.
Would this be a sign of a bad brake master cylinder? No leaks from any lines that I can see. Or would that be something to do with the booster?
It doesn't gain any pressure if I pump it so leads me to believe it's a reservoir. Or if there anything else I should look at?
Old Oct 17, 2025 | 11:46 AM
My4Fordtrucks's Avatar
My4Fordtrucks
When was the last time you cleaned and adjusted the brake shoes?
Old Oct 17, 2025 | 11:47 AM
Franklin2's Avatar
Franklin2
Air in the system somewhere. Have you bled them?
Old Oct 17, 2025 | 01:23 PM
Max Capacity's Avatar
Max Capacity
At this age, if you need, replace the booster and the master at the same time. These are your brakes. I did that a few years back, okay, maybe 8 or 9 years, time goes by fast.
Make sure you don't have a rear wheel cylinder leaking.
Old Oct 17, 2025 | 05:02 PM
Yipe's Avatar
Yipe
3rd Gear
No leaks anywhere, haven't bled system just bought the truck not long ago. Although the rear brake line does look newer so possibly never got bled properly.
Old Oct 17, 2025 | 06:07 PM
kr98664's Avatar
kr98664
Problems with the rear brakes can also affect the front brakes, strange as it may seem.
Definitely try bleeding the rear brakes. If no help, make sure the rear brakes are properly adjusted. If still no help, you’ll likely need to do a full system pressure bleed. Lots more details here:
https://www.ford-trucks.com/forums/1...-bleeding.html
Old Oct 21, 2025 | 07:03 AM
5starCabF-3's Avatar
5starCabF-3
Adjust the rear brakes
Truckbuck
Jul 16, 2025 05:38 PM
Amish65F100
38
May 25, 2017 11:10 AM
timbersteel
Apr 25, 2016 11:11 PM
custom cabby
Apr 11, 2010 01:39 PM
califasbob
13
Aug 25, 2007 08:33 PM
