LED headlights 2004 explorer E B
Old Oct 6, 2025 | 12:42 PM
billybe4od's Avatar
billybe4od
AHREN 9005 9006 Light Bulbs Combo Pack, 60000LM 900% [Modern & Ultra Bright] Super Bright Bulb 1:1 Mini Size No Adapter Required, 6500K Cool White HB3/HB4 Compatible, Plug-and-Play, Pack of 4
hi all , would these led lights be plug an play without any issues? An HOW. Fo you change the bulbs Looks like removing the whole headlights assembly.
thanks for any reply
Old Oct 6, 2025 | 05:27 PM
shorod's Avatar
shorod
Does your Eddie Bauer have the lamp out warning? If so, these may not be a direct fit without a load resistor/CANBus error device.
You should not need to remove the entire headlight assembly to replace the bulbs, the bulbs are installed from behind the headlamp assembly. There are likely videos that will explain this better than words.
-Rod
Old Oct 7, 2025 | 03:11 PM
billybe4od's Avatar
billybe4od
No lamp out warning I just wanted brighter lights
umm, the headlights need to be removed from the vehicle it’s pretty easy , I hope it’s just a plug and play
Old Oct 7, 2025 | 03:16 PM
billybe4od's Avatar
billybe4od
Old Oct 7, 2025 | 08:39 PM
shorod's Avatar
shorod
Oh, interesting. Apparently either the Mountaineer is different or I never had to replace the bulbs in it.
Regarding the lamp out warning, I am referring to the information center displaying if you have a headlight out. LED headlights draw less current than the OEM bulbs, so converting to LEDs could cause the info center to think the headlights are not working.
-Rod
Old Oct 8, 2025 | 05:36 AM
billybe4od's Avatar
billybe4od
Ok , thanks for the heads up on that ,
I hope it’s just plug an play
I ve owned since new 2004 an don’t want to be messing with the bulbs
mattd17
Oct 3, 2018 06:54 AM
jjg197804
Sep 6, 2006 09:16 PM
jmms
Oct 26, 2004 09:13 AM
