351w? 351c?
Old Dec 7, 2003 | 11:47 PM
llee's Avatar
llee
351w? 351c?
I have an 84 F350. Some previous owner put in a 351 replacing the deisel in it. I am about to do some major work to it to get it running again but I dont know if its a Cleveland or a Windsor. There are no stickers on the valve covers or anywhere else. Is there a way to tell which it is before I pull the engine? I would like to start buying the parts before I get it all apart.
Thanks
Old Dec 8, 2003 | 09:29 AM
80broncoman's Avatar
80broncoman
One of the easest ways to see the difference is that the W engine
thermostat housing bolts to the front of the intake manifold. the
Clevland enginge bolts straight down on the block.
A Windsor valve cover is the same as a 302.
A Clevland vavle cover is the same as a 351m and 400m
A Windsor's fuel pump bolts are side to side
A Clevland's fuel pump bolts are top and bottom
Old Dec 8, 2003 | 09:13 PM
ground_poundin's Avatar
ground_poundin
the waterpump on a windsor bolts to a aluminum cover, if i remember the waterpump on the cleveland is bolted to the block...kinda unsure right yet, also a cleveland has round port heads so the exhaust and intake manifolds kinda reflect its large ports. both have the same engine mount and sml blk trans pattern, just a couple other ideas...i hope you have the cleveland. good luck
Old Dec 8, 2003 | 11:22 PM
llee's Avatar
llee
Well its now official. I have a Windsor in it. The whole time I was pulling the wiring harness off I never even looked at the thermostat housing. Well I guess for a dollar I still got a good deal!
Thanks Again!
Aus56
18
Jul 3, 2013 03:55 AM
FireBlue
28
Feb 9, 2010 10:09 PM
calazo
16
Jun 23, 2004 04:46 PM
Tugboat Joe
Aug 24, 2003 02:01 PM
84Maztang
Jun 13, 2003 04:58 PM
