2021+ Bronco Discussion for the upcoming 2021 Ford Bronco!
Engine
Old Sep 25, 2025 | 12:25 AM
claycomotrucks1991's Avatar
claycomotrucks1991
Engine
Can we please get a non turbo motor with some cubic inches in size?
Old Sep 25, 2025 | 08:12 AM
99powerstrokedF250's Avatar
99powerstrokedF250
No one from Ford is going to listen to you on this forum.
There are some guys over on Bronco6g that have put the Coyote motor and a 7.3 in a Bronco. Forget working on it if something goes wrong without pulling the body off.
But honestly? I have a 2-door Sasquatch with the 2.7 and it will bark the rear tires, and it will pull the front tires about an inch off the ground if I brake torque it and have good traction. That's WAY more than enough power for such a small vehicle. And while I don't know what the quarter mile times are, I've surprised many hot rods who thought they were something at a stop light.
Old Sep 29, 2025 | 02:57 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Turbos have been the replacement for displacement for over 100 years and this is our future in the petroleum world. The trade off is, you sacrifice some endurance in the gasoline segment.
Old Sep 30, 2025 | 11:07 AM
seventyseven250's Avatar
seventyseven250
I think the market and Ford have answered this as an unequivocal "NO".
Old Oct 1, 2025 | 09:00 AM
99powerstrokedF250
And even that is somewhat up for debate, as a properly constructed engine, one designed and built for a turbo application, can and will last as long as a naturally aspirated engine. Now, do I trust most OEMs to do it properly? Absolutely not, especially when they consider the lifetime of a vehicle to be roughly 100k miles.
Old Oct 1, 2025 | 09:03 AM
99powerstrokedF250
Yeah I mean the aftermarket has stepped up and started supplying a lot of aftermarket performance parts and tunes for both the 4-cyl and 6-cyl Broncos. But the reality is, for what the vehicle IS, you don't really need, or even really WANT, a big heavy V8 under the hood to do some pretty serious off-roading in these things. I mean if you're just wanting to go jump dunes, okay, but you're already likely starting off in a Raptor which is already hopped up pretty good.
Not to mention there just isn't much room under the hood of these Broncos. The V6 is pretty tight to work on.
dethpulse
Sep 16, 2018 08:37 PM
bluemtn95ford
Dec 3, 2015 08:20 PM
david00f150
Mar 11, 2010 06:02 PM
Milwaukee,WI
Mar 13, 2006 12:07 PM
highboy 74
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Dec 25, 2003 07:12 AM
