Help 7.3 idi won't run
Old Sep 23, 2025 | 08:12 PM
Russell3's Avatar
Russell3
4wd Low
Originally Posted by tjc transport
99.9%of starter relays are made chinesium, and their quality control is almost non existent. i have seen 5 in a row bad out of the box.
i always try to get made in mexico if made in usa is not available. while made in mexico is not as good, it is still 400 times better than made in chinesium.
Makes sense ill definitely do I that way from now on
Old Sep 23, 2025 | 08:13 PM
Russell3's Avatar
Russell3
4wd Low
Originally Posted by ihc1470
Sometimes if the batterys are low and you try cranking it will weld the contacts on the solenoid.
They were not welded but if they were could i separate them and still use solenoid if that does happen
Old Sep 24, 2025 | 10:43 AM
ihc1470's Avatar
ihc1470
Sometimes. Depends on condition when you get to them.
Old Sep 24, 2025 | 02:21 PM
knottyrope's Avatar
knottyrope
dont over tighten the large lugs on the relay
the copper lugs can turn inside the relay making it not work so well as it uses the bolt heads as part of the switch
Old Sep 24, 2025 | 04:18 PM
Russell3's Avatar
Russell3
4wd Low
Makes sense
Old Sep 24, 2025 | 04:19 PM
Russell3's Avatar
Russell3
4wd Low
will make sure to not over tighten
caitlyn0255
Sep 13, 2022 10:34 AM
Willar47
Jan 3, 2022 12:01 PM
Fl.Cowboy 65
Mar 15, 2014 02:56 PM
cashman89
Mar 23, 2010 08:54 PM
