Heater Control Panel Restoration
Old Dec 7, 2003 | 08:33 PM
Duthlerfordparts's Avatar
Duthlerfordparts
Does anyone have any suggestions for restoring the heater (A/C) control panel? The edges around the inner face panel are bleeding light. I thought of just repainting the whole thing, but the way Ford labeled them, there is really no way to protect the lettering.
Old Dec 8, 2003 | 04:49 PM
lotsafords's Avatar
lotsafords
I just grabbed the best one out of my many junkers, dissasembled and polished with a regular plastic polish on a buffing wheel just for plastic products.
Looks great.
As for the bleeding light, maybe touch up with a flat black on the back side of panel?
Old Dec 8, 2003 | 05:25 PM
BigBully's Avatar
BigBully
I use the ones from a newer truck. Like an 86 model For example. Its a bit different but it can be made to work. I like the colors instead of just black and white.
Old Dec 9, 2003 | 01:21 PM
ivanribic's Avatar
ivanribic
I did the same as bigbully. Went to a wrecking yard and pulled the face off of a newer Ford van. The only think I had to do was cut a notch for the fuel selector, on the right hand side. It looks much better than the old one, with the red and blue deals for the temperature. That is, of course, unless you are trying to restore your truck to look like original.
