E40d issues
Old Sep 11, 2025 | 04:02 PM
Davon3598's Avatar
Davon3598
E40d issues
Hello everyone, I just picked up a 96 f250 7.3 powerstroke 2WD. It has the E40d transmission. Starts up and runs very well. However, it does not want to move. It will engage the gear I believe because the engine rpms go up and down when changing gear selector. I decided to throw more transmission fluid in it today and it moved forward. I put it in park again to go close the hood and hopefully drive it and nothing. Doesn't want to move again. Is the transmission shot? I do not hear anything out of the ordinary.
Old Sep 11, 2025 | 06:04 PM
z31freakify's Avatar
z31freakify
Have you checked to see if the oil level is up to the hash marks? Possibly a fallen trans filter
But checking for transmission codes will be your best bet.
FORCAN and an OBD 2 dongle is the cheapest diagnostic tool you can aquire that will resd trans codes.
Old Sep 11, 2025 | 10:17 PM
Davon3598's Avatar
Davon3598
Thank you! Just dropped the pan and no obvious damage at first but the transmission is definitely shot. I can hear some kind of rattle, clank or metallic sound off and on and I saw quite a bit of metal shavings in the fluid. Going to pick up an E40D from a 95 f350 tomorrow and hopefully it all works out.
Negative Covfefe
Dec 1, 2021 02:42 PM
Mattst13
Oct 27, 2021 02:04 PM
Jakeman46
Jan 15, 2017 01:06 PM
big79bronco
Feb 12, 2013 06:30 PM
664x4100
Feb 26, 2007 01:34 PM
