Hard cranking
Old Sep 11, 2025 | 11:01 AM
artur's Avatar
artur
2nd Gear
Hard cranking
Hey everyone, I recently purchased f250 2017 6.2 97k km.I Used to have occasional long cranks, only when warm which is common for fuel pump. Recently the long crank went away, but now the truck stumbles or misfires briefly while cranking - it almost dies,then catches and runs fine. This happens on both warm and cold starts now. It’s never failed to start, just struggles
So far I replaced the purge valve, battery brand new , cycling the key before start doesn’t help, no check engine light, no codes.
What could it be?
Any advice on where to start testing would be appreciated.
Also I attached a video below
Old Sep 15, 2025 | 01:25 PM
bigdehart64's Avatar
bigdehart64
2nd Gear
mine did the same thing. Changing batteries fixed it
Old Sep 15, 2025 | 01:47 PM
Moonze's Avatar
Moonze
7th Gear
What could it be?
Used to happen to my '94 F-250. Then I changed the ground wire from the battery to the chasis. Cleaned all points of contact and battery terminals. Now it starts like a champ.
42walabywaysydney
May 20, 2024 11:30 PM
peytonbaros
Apr 22, 2023 11:09 PM
Mr.Gibble
97
Jan 13, 2023 01:13 AM
mhaines15
Jan 28, 2022 06:13 AM
BigMoose62
Dec 3, 2019 08:36 AM
