ECM Identification
Old Sep 11, 2025 | 08:42 AM
jrhinehimer's Avatar
jrhinehimer
7th Gear
ECM Identification
Is there a chart somewhere that helps decode the numbers on the ECM on the 90s fords? F4TF-12A650-BBC is what I have on an older one but would like to understand what each group of numbers means. I know the F4 identifies it as a 94.
Old Sep 11, 2025 | 10:17 AM
wwhite's Avatar
wwhite
Some people here have documentation, don't think its posted, would be nice.
[Prefix] - [Base Part Number] - [Suffix]
F4TF:
  • F = Decade: 1990s
  • 4 = Year: 1994
  • T = Vehicle line or division: Truck Division
  • F = Engineering department: Electronics (Powertrain Control Module or similar)
12A650
  • 2A650 is the standard base number for Engine Control Units (ECUs) across Ford vehicles.
BBC
  • Calibration Code / Revision — used to match to specific vehicle application
Software/Calibration: BUG2
Hardware: SMD-219, MAF 60-pin OBD1, 4R70W, 5.0l
Federal emissions, non-cali.
All the above is pretty much from memory, other than vehicle search shows could be
Bronco, F-x50 and/or E-x50.
Old Sep 12, 2025 | 07:32 AM
manicmechanic007's Avatar
manicmechanic007
You got a pretty good memory wwhite
Old Sep 15, 2025 | 11:20 AM
jrhinehimer
7th Gear
Thank you for your help!
SwampRattFord
Jun 14, 2022 07:20 PM
