Overheating issue with 1994
Old Sep 6, 2025 | 11:46 AM
Kofire's Avatar
Kofire
1st Gear
Hi I recently acquired a 1994 ford explorer. There was no overheat issue I just chose to proactively do some preventative maintenance and upgrades at the same time. It ran good but had an original radiator etc.
So. I put in an AlloyWorks 3 row radiator, new acdelco water pump, new thermostat housing, thermostat, proform brushless 14” efan which flows 2900 cfm.
As soon as I got everything installed and running I immediately started having overheat issues. I bypassed the heater core to see if that was it and it helped but I am still seeing high temps with the AC on. Much higher then I saw previously before all the work I did. I’m starting to run out of ideas. Does anybody have any suggestions or path to choose moving forward? I have tried with no thermostat, 180 thermostat, 195 thermostat and there is no difference.
If I’m accelerating hard with the ac on it will climb to the “l” rapidly. Thanks.
Old Sep 6, 2025 | 03:09 PM
aquanaut20's Avatar
aquanaut20
Go back to the original fan and make sure the rad shroud is fitted properly
