Alarm keeps going off
As the title says, I'm having issues with the alarm occasionally going off for no reason. I have not seen any random hood ajar or door ajar messages. A lot of the stuff I've found online says the hood latch is a common source of this problem, but IDK if that's my issue. My hood latch looks different from all the ones I've seen on YouTube. I don't even see a wiring harness connector on it. I know it has a hood sensor, but I don't know where the wires for it are located. I don't want to just throw a new hood latch at it and hope that fixes it.
I'm wondering what my options are for diagnosing. I have a bluetooth OBD II dongle and Car Scanner app on my phone, but it doesn't appear to show alarm sensor data (at least not that I could find). I'd have to buy a laptop and OBDLink adapter if I wanted to use Forscan. So $70 for the adapter and $180 for the cheapest laptop at Walmart, $250-ish all in. Not sure what my local Ford dealer charges for diagnostics, but I'm guessing a similar amount. Is there any other way to diagnose this issue?
Is the aftermarket tailgate a possible culprit? Not sure if there is a security sensor for the tailgate.
I've also heard people say they've changed their security settings to "perimeter only" in case there's a bug flying around inside setting off the motion detectors. I'm not finding where to do that in my gauge cluster. Can anyone point me in the right direction?
Thanks much.
Thanks much.
To set your security settings to 'perimeter only,' I THINK you can change that in the settings through the radio (not gauge cluster), otherwise every time you shut the truck off a screen should pop up with the selection of 'perimeter only' or 'all sensors.' Side note, if your teenager wants to sit in the back seat while you run inside real quick, make sure to set it to 'perimeter only' or it WILL set the alarm off if he moves.
According to my manual, the alarm is armed any time the doors are locked electronically (either using the fob or using the lock button on the door), so if you lock it from outside using the key, the alarm should not be armed. You have to have your unlock strategy set to two stage unlock, which can be done via the vehicle menu on the gauge cluster.
Be aware that your alarm is not set when you do this, so you are vulnerable to a break-in.
After doing a little more online searching on how to actually fix the problem, I'm pretty sure I'm going to have to either take it to a dealer or get the stuff I need to use Forscan to diagnose it. Otherwise it's just a guessing game.
https://www.youtube.com/shorts/j1slW35M0Kk
I asked the service advisor where that sensor is located since I could not find anything electronic-looking on the actual hood latch. He said it's off to the side - I haven't looked yet, need to get in there and see if I can find it for future reference.
If I had the proper scan equipment, I could have done it myself for less. But I just didn't have time to mess with it this week, nor the time to wait on the new OBDII adapter to be delivered. And the wife wasn't crazy about spending another 250 on more "stuff for the truck" right now.
So the hood sensor on my truck is located in front of the driver's side battery, next to the upper radiator hose. Easy to reach, would have been super easy to replace. Now I'm not feeling so great about $150 of labor for something that probably took half an hour to diagnose and replace. But I still paid less than it would have cost me to get up to speed on diagnosing this stuff.
More sleuthing is needed.
I wonder if changing all the bulbs to led is possibly causing this somehow. I did change the mirror turn/ running and all the lights in the back (brake, running, reverse) to led bulbs. I guess I'll change them back and see what happens.
