Trailer plug question
Old Sep 3, 2025 | 03:03 PM
Frank79's Avatar
Frank79
I bought a light strip to mount on the pinch weld near the running boards.
The light strip has running (amber), turn signal (amber) and a white light when you open or unlock your door.
Before I go Freddy Krueger on the factory harness, is it possible to wire this contraption to a 4 way or 7 way trailer plug?
https://a.co/d/4Fegmi1
Old Sep 3, 2025 | 04:20 PM
seijirou's Avatar
seijirou
Except for the door opening to give you white, typically yes. Ford does try to make trailer wiring more complicated than it needs to be lately so I'd just give it a quick test with a multimeter and see if you have power at the trailer plug with the running lights on or not. Also unknown to me if the truck would "see" them as a connected trailer or not, but LEDs are high resistance/low current much like a multimeter so I'd think not.
Old Sep 3, 2025 | 04:25 PM
Frank79's Avatar
Frank79
Originally Posted by seijirou
Except for the door opening to give you white, yes.
Thanks!
i guess I would probably need to tap into the fuse that operates the door lights then.
Old Sep 3, 2025 | 08:21 PM
Frank79's Avatar
Frank79
I didn’t see anything in the manual that shows a fuse for the interior lights.
I’m not sure if it’s grouped with one of the other 200 fuses the truck has. Only thing that came close is the driver door module. Not sure exactly what it’s for, but I’ll try and get a probe on it in the next few days and see if it’s something that I can tap into
Old Sep 3, 2025 | 09:00 PM
1olddogtwo's Avatar
1olddogtwo
Be aware that your truck will always think there's a trailer attached.
Old Sep 3, 2025 | 09:45 PM
Frank79's Avatar
Frank79
Is that a bad thing?
Old Sep 3, 2025 | 09:50 PM
1olddogtwo's Avatar
1olddogtwo
I guess that'd be your personal opinion.
Every time you start a truck you'll have warnings on the dash for example.
Your miles to empty will calculate different also, Sooner or later that would even out if you continue to leave plugged in.
The Peddler
Sep 12, 2024 09:26 PM
Armyrules2
Sep 4, 2023 08:24 PM
crucialprospect
17
Mar 31, 2018 03:57 PM
lkay1
Jan 14, 2015 11:18 PM
tenptbuck7mmmag
2004 - 2008 F150
Apr 21, 2006 11:24 PM
