Did the Highboys (73-77) ever have a rear stabilizer bar option?
I realize that the 2wd versions may have but my question is specific to F250 4WD.
Thanks in advance
Tbriuz
The F250 Camper Specials came with rear sway bars. They were mounted over the top of the banjo housing.
The front sway bars mounted between the radius arms.
I added them to my 68 F 100 many years ago when you could buy them from Ford. I had to mount the rear bar under the banjo for shock absorber clearance and fabricated some linkage.
Addco has sway bar kits that will fit your truck.
