Bad vibrations
Old Aug 29, 2025 | 01:08 PM
C7XR7's Avatar
C7XR7
Bad vibrations
2022 F250 6.7L 23,500 miles on the odometer
2 Months of traveling, occasionally pulling our 30' Travel Trailer as we changed locations from state to state. On the way back home while pulling the trailer, we started getting steering column and steering wheel vibrations (not back and forth but up and down) every time the speedometer hit around 58 MPH. It was a 5-MPH range each way from 58. I also noticed it was mostly in 8th gear. What do you think might cause this? Doesn't seem like a death wobble situation. Is the transmission slipping or some other component failing? Does not happen at all when not towing. Thoughts?
Old Aug 29, 2025 | 07:36 PM
BC2019F250's Avatar
BC2019F250
I would look at tires first.
Old Aug 30, 2025 | 09:27 AM
Mike Bartlett's Avatar
Mike Bartlett
If nothing else get the tires balanced and rotated then go from there.
Good luck,
Mike
Old Sep 2, 2025 | 11:48 AM
scottz99's Avatar
scottz99
Veteran: Navy
I had a similar vibration at 70+; towing or not. Balanced tires several times, no help. I found a shop that could true tires; they found one of the front tires out-of-round and trued it; been good since then.
Old Sep 2, 2025 | 01:38 PM
99powerstrokedF250's Avatar
99powerstrokedF250
Tough to say without some investigation, but definitely look at tires first. Could even be a driveshaft lost a weight but that's usually felt in the seat not the wheel.
Old Sep 2, 2025 | 02:52 PM
mhollem's Avatar
mhollem
Swap the front tires with the back tires and see if it disappears.
John in OkieLand
Jan 15, 2025 02:33 PM
Curated Content Editor
2022+ F-150 Lightning EV
Apr 28, 2022 01:07 PM
riley3131
Apr 25, 2018 10:05 AM
almightywad
All Things Towing
19
Dec 16, 2017 03:25 PM
PacMan90
6.2L V8
15
Mar 18, 2013 05:47 PM
