E4OD Transmission
For Sale
Drivetrain
  • Drivetrain - E4OD Transmission - Used - All Years  All Models - Buckeye, AZ 85396, United States
    Sold
    Sold
  • Price
    $275
    • OBO
  • Location Buckeye, AZ, 85396, USA
  • Condition Used
Description:
RF-FOTP-7008-AB part # An automatic transmission for a 1994-1997 F-250 or F-350 truck equipped with a 7.3L diesel engine or a 7.5 Gas motor. E4OD transmission, leaks from the front pump but I will throw in a brand new seal. Solenoid pack included but condition is unknown , and will need a new valve body gasket ($17 for a set). Comes with a pan but missing some bolts, this is a 94-97 transmission. I bought an old F250 7.5 460ci V8 RWD with this fitted but this transmission was the wrong one for the truck - Electronic Speed Sensor and my truck needs the mechanical one. Previous Owner was inexperienced. Priced for a fast sell. I ran out of time to recondition this one, if it doesn’t sell fast I’ll do the work myself and it will be priced accordingly. 4 Speed with Overdrive.
Old Aug 25, 2025 | 03:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What engine was it mated to?
Old Aug 26, 2025 | 07:53 AM
Aedhasdad's Avatar
Aedhasdad
Came off a 460 big block - 7.5 V8
but fits many applications and vehicles that used the E4OD
from Google:
The Ford E4OD transmission was used in 1989-1997 Ford F-Series trucks (F-150, F-250, F-350), the Bronco SUV, and E-Series vans. It was also used in the Ford Expedition and was available with different bellhousing patterns to match small-block, big-block, and diesel engines.
Specific Vehicle Applications
  • Ford F-Series Trucks:
    The E4OD was a staple in F-150, F-250, and F-350 pickup trucks from 1989 to 1997.
  • Ford Bronco:
    This transmission was also used in the Ford Bronco SUV during its production years.
  • Ford E-Series Vans:
    E-Series cargo and passenger vans were equipped with the E4OD transmission.
  • Ford Expedition:
    Early models of the Ford Expedition also used the E4OD transmission.
Engine Compatibility
The E4OD was designed to work with a variety of engines and was produced with different bellhousing patterns:
  • Small-Block Gas Engines: Compatible with engines like the 300 inline-6, 302, and 351 Windsor.
  • Big-Block Gas Engines: Used with big-block engines, such as the 460.
  • Diesel Engines: Paired with engines like the Ford 7.3L Powerstroke diesel and the International Harvester IDI diesels.
Old Aug 26, 2025 | 09:07 AM
Mark Kovalsky
True, but that trans won't bolt to a small block or a diesel.
Old Aug 26, 2025 | 09:31 AM
Aedhasdad's Avatar
Aedhasdad
Correct as is - swap the bell housing from the one your’re replacing.
Old Aug 26, 2025 | 01:27 PM
Mark Kovalsky
To swap the bellhousing you have to cut the old one off and weld the new one to the case. That's nearly impossible.
Old Aug 26, 2025 | 01:44 PM
Aedhasdad's Avatar
Aedhasdad
My bad, I’m used to classic British cars… where you can do that
swap the guts then.
point is, a working transmission for well below market price.
