Hello all,
Searched and found conflicting information. Can anyone provide the correct spring code or part # for the snow plow prep pkg front coils for a non-Tremor 2022 F250 4wd cc/sb 7.3L gasser. I’m adding a plow this winter and currently have the 4800/NNll setup. Looking for the 6000lb #’s. Asked at the dealer and was told they can’t look it up without the vin from a truck with that setup or the spring codes. Any help would be greatly appreciated.
Hello all,
I did some research a few years back and found this information on here. Looks like one of those you responded to it. I can not guarantee fitment because I ended up not upgrading. Maybe this will help.
So most of our stuff matches, except I have the 6.7 and yours is a 7.3. Otherwise, 2022 Non-Tremor, 4x4 crew cab, SWB F250 (even Antimatter Blue!). I added the high capacity tow package and the snow plow/camper package to mine. My front springs are 5990 lbs, which is the F250's way of derating the same 6000 lb springs. Here's a photo of the tag on mine. Hope it helps!
Thanks, that’s the part # I came up with as a match for my truck. Found a set of new take offs on ebay for $80,(dealer wanted $246 each!). FedEx delivering them today.
