AC Problems 04 Excursion
Old Aug 20, 2025 | 07:13 PM
loughlogand's Avatar
loughlogand
1st Gear
Hi I'm having issues with my 2004 Ford Excursion 6.0 with it just blowing out the defrost. The AC is cold but will not switch. I have replaced the vacuum lines, the blend door actuator, and vacuum pump. I am getting good vacuum, the ESOL works perfectly but I still cannot get the AC to switch from the defrost setting. Not sure what else to check or what else to look for at this point.
Any help would be appreciated. Thank you.
Old Aug 21, 2025 | 03:01 AM
charlie g's Avatar
charlie g
FTE Community Team
welcome to the best of the best for ford truck help
by default when there is NO vacuum, heat and a/c automatically runs defrost only, make sure you have it to the switch , start at the engine work into the dash ,make a post in https://www.ford-trucks.com/forums/forum29/ asking for more detailed help
good luck,
Old Aug 22, 2025 | 10:27 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I agree with @charlie g, start a new thread in Excursion - King of SUVs and/or start one in 1999 - 2016 Super Duty. They'll be able to get you going!
Welcome aboard!
Snowqueen
New Member Introductions
Jul 30, 2022 04:26 PM
Chris_Wilson
Mar 13, 2007 05:17 PM
michaellhodges
Oct 25, 2006 01:51 PM
FTE Ken
Site Announcements
Jul 22, 2002 03:58 PM
