51 Ford speaker
Old Aug 18, 2025 | 01:54 PM
Built51's Avatar
Built51
5th Gear
51 Ford speaker
I have no idea how to send a private message to someone.
Will someone tell me how to send a private message thru this forum.
Thank you Built51
Old Aug 18, 2025 | 01:56 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
You click their name and select send message.
Old Aug 18, 2025 | 01:57 PM
52 Merc's Avatar
52 Merc
If you click on the person's user name, a drop down menu will open with an option to send them a private message. You may not have made enough posts yet for that option to be available to you. Respond to a few more posts to build your post count and it will become available.
Old Aug 18, 2025 | 04:54 PM
Fomoko1's Avatar
Fomoko1
I think you have to also to click on user profile.
No. of posts required for PM's (Private Messages) to be active?
5 posts + 10 days as a registered user
Old Aug 18, 2025 | 05:30 PM
56panelford's Avatar
56panelford
Thank you Built51
Using Wayne's post as an example , clicking on his user name will drop down a window, you then have the options to what you require..also what has been said you will need a few more posts ..
Old Aug 19, 2025 | 03:34 PM
Built51's Avatar
Built51
5th Gear
Box side panel movement
So I have another question. How do I stop the box side panels from flexing at the tail gate. I have welded the side panels to the lower cross member, but when the rear box panel at the tail gate is pulled apart it moves out. It does not move vey much but as I drive the truck I think these panels will continue to flex and open up wider at the tailgate.
Thanks for your help, Built51
Bonanza35
Jul 5, 2014 06:47 PM
Mil1ion
Jan 23, 2002 07:56 AM
