Welded diff!
Old Aug 15, 2025 | 12:42 PM
Goozzman's Avatar
Goozzman
Welded diff!
Hi guys,
In my project of converting a Ford F-250 from 1973 into a thirties racer I encountered my first real drawback! Until now everything went smooth, but today I found out that the diff of the Dana 60 axle is welded together. I will drive it on the road only, so this is no good for me. What should i do? I have two options:
1. Get myself new spider gears. I saw that they are available (around $ 100) and some do ship to The Netherlands. But I'm not a skilled mechanic..
2. Get myself another Dana 60 axle. Hard to get in NL.
What route would you guys take?
See my vid here on YouTube for the details:
Old Aug 15, 2025 | 12:59 PM
Viper Pilot's Avatar
Viper Pilot
Dang, sorry you ended up in that situation. If you choose to replace the spider gears here is a good video.
Old Aug 15, 2025 | 01:08 PM
Fleur de lis 82's Avatar
Fleur de lis 82
New spiders are gonna be the cheapest route. But getting the old welded gears out could be difficult, unless you've got a cutting torch. New carrier & spiders may be the easiest option, but then a setup is needed.
To bad its not a Dana 70, I've got a complete carrier you could have.
Old Aug 15, 2025 | 06:58 PM
440 sixpack's Avatar
440 sixpack
Clowns used to do this for drag racing. it's not a hard or expensive fix just go for it and get some professional help if you feel you're in trouble.
Old Aug 15, 2025 | 08:27 PM
Wangdangdoodle's Avatar
Wangdangdoodle
That's unfortunate. Even more so, since I am about to pull a dana 60 from my truck that you could have.
Old Aug 17, 2025 | 04:14 AM
Goozzman's Avatar
Goozzman
Thnx man! If I lived near to you I would thankfully accept your generous offer, but shipping it to The Netherlands would make it make it the most expensive old Dana 60 axle ever
Old Aug 17, 2025 | 08:27 AM
DaveMcLain's Avatar
DaveMcLain
Welded spider gears, AKA a "Lincoln Locker". I think that you'll be able to get it apart without destroying your differential carrier with some careful cutting and a new set of spider gears.
4x4Van13
Feb 14, 2022 08:19 PM
77fummins
Jan 14, 2017 06:49 PM
CortStrasser
Dec 10, 2014 11:38 AM
F250351W
Aug 16, 2010 07:36 PM
Tom
May 11, 2009 09:43 PM
