Steam without Blowby
Old Aug 7, 2025 | 06:07 PM
Boaterguy's Avatar
Boaterguy
Before everyone jumps on me, yes, I did search around but could not find a definitive answer.
I have a 2105 F250 4X4 CC, PSD with 127,000 miles on it. Bone stock except for the DCR pump upgrade. For the last couple of oil changes, I noticed that I was getting some steam from the oil fill cap when I removed it. You can't really see in the pic, but with engine running, I am getting a steady stream of steam out of the filler tube. I flipped the cap over while running and the cap didn't budge, so no blow by i guess. I am not losing any coolant, and the CCV box was replaced a while ago under customer satisfaction program 17M04. Is this anything to be concerned about?
Old Aug 7, 2025 | 07:38 PM
Overkill2's Avatar
Overkill2
That's not steam but the actual blowby or gases that get by the piston rings and pressurize the crankcase.
Here's it explained better than I can...
https://en.m.wikipedia.org/wiki/Cran...ilation_system
This is for marine applications but has good info:
https://stevedmarineconsulting.com/c...does-it-serve/
another one:
https://www.solbergmfg.com/blogs/blo...lation-systems
So it appears your CCV box is not plugged and flowing well. If it wasn't, then you would have your oil fill cap blowing off indicating your crankcase is over pressurized which could lead to a upper oil pan leak do to the crankcase pressure not being relieved.
Those gases are produced by everyone's 6.7 engine here...
Old Aug 7, 2025 | 08:12 PM
Boaterguy's Avatar
Boaterguy
Thanks for the info. I was getting concerned because it seemed to have only started, or at least became noticeable, the last 2 or 3 oil changes.
Old Aug 7, 2025 | 09:51 PM
Overkill2's Avatar
Overkill2
No problem. Glad to help... guys who do the CCV relocate and vent it to an open hose underneath the truck will tell you they see that as well.
muskin13
May 4, 2021 04:16 PM
swellman
Modular V10 (6.8l)
Jan 27, 2021 11:22 AM
Dorifuta
Aerostar
May 7, 2012 01:40 PM
buell.rider
20
Apr 4, 2011 09:39 PM
somegeek
2004 - 2008 F150
19
Jan 13, 2006 08:41 AM
