Bronco II Ford Bronco II
4wd dont eng.
Old Dec 7, 2003 | 08:39 AM
muddawg's Avatar
muddawg
Angry 4wd dont eng.
I have a 90 b2 and all the fuses are good in cluding the ones under the hood. i heard that there is an aftermarket manual kit that can be installed. Anyone heard of this or know where to find it? would rather have a manual shift if i can.
Old Dec 7, 2003 | 09:27 AM
GrayRanger4x4's Avatar
GrayRanger4x4
I dont know of any kits for your t-case ,but you can swap it for a manual shift t-case.
As for you problem it sounds like you elec. motor on the t-case is bad.Crawl under the truck ,find the back side of the t-case there should be a small elec. motor on the t-case Tape it ((((LIGHTLY ))))with a hammer and see if the 4x4 works.You might have to take it off and clean it. Good Luck!!
Old Dec 8, 2003 | 04:04 PM
jmh1's Avatar
jmh1
Trailering
I would agree with grayranger....sounds like the motor on the transfer case. When you hit your 4x4 button, do you here a solenoid clicking? Do the lights come on?
