79' to 80' changes
Old Dec 7, 2003 | 04:55 AM
2tailfins's Avatar
2tailfins
79' to 80' changes
I am interested in getting (another) old pickup (pre 1980) but what is the difference in the chassis? i noticed that aftermarket suspension is always 65' to 79' or 80' to ? is there a huge difference in the TTB between 79' and 80'?
Old Dec 7, 2003 | 07:54 AM
bremen242's Avatar
bremen242
there is a big difference. It is because 79s (4x4s at least) don't have TTB. they have solid front axles..
Old Dec 7, 2003 | 02:34 PM
2tailfins's Avatar
2tailfins
is there a difference in the frames? length, track width, wheelbase? (only on 2wd TTB) Thanks!
Old Dec 7, 2003 | 02:54 PM
bremen242's Avatar
bremen242
that I am not 100%. I know the rear axles have the same spring perch width.
are you thinking about swapping in a 4wd TTB from an 80+ truck?
Old Dec 7, 2003 | 03:07 PM
2tailfins's Avatar
2tailfins
no actually I am building a prerunner desert truck and all of the suspension manufacturers seem to cut off at 1980 their kits. if i need to do some fab to get the later kits to fit, thats ok. just curious why the 79' to 80' seems to be a cutoff. check out
www.McneilOff-Road.com to see what I want to do.
Old Dec 7, 2003 | 06:08 PM
dashashopdog's Avatar
dashashopdog
well ther was a major change to the front end on the 80 2wd. no one really make the kit because there are very few 79s left. the suspension didn't change again till 97 on the 2wd. so it isn't like there is more 80's left. the reason it wont fit is the differnce in the i beam arm length change in 80. though in theory and by my collision books, the frame width is the same, so you could install the 80 and later crossmember and i beams, but not sure to the front spring perch widths.. Kurt
Old Dec 8, 2003 | 03:20 AM
2tailfins's Avatar
2tailfins
Thanks! time to get out my tape measure and go to the junk yard I guess
Old Dec 8, 2003 | 04:27 AM
dashashopdog
believe the change was the early trucks had unequal i beams and the later trucks had equal length. or maybe the other way around? my 81 looks to be the same side to side, and i dont have a 79 and earlier 2wd to look at right now. hope that helps a little more.. kurt
ibleedblue1385
1978 - 1996 Big Bronco
Mar 19, 2013 01:57 PM
crestfallinman
Mar 1, 2011 01:24 PM
Arpey
Mar 17, 2010 11:34 PM
tetraruby
Exhaust Systems
May 13, 2001 09:48 AM
