1999 expedition
Old Jul 31, 2025 | 10:59 PM
Jcards's Avatar
Jcards
7th Gear
1999 expedition
Any suggestions on air conditioner not blowing cold air and clutch will not engage. New compressor ,filter dryer, condenser, acutator , high and low side valves .. still no cold air.
Old Aug 1, 2025 | 08:09 AM
Hit Man X's Avatar
Hit Man X
Bad high side switch?
Test the power flow to low switch and the high side switch.
Old Aug 1, 2025 | 08:38 AM
alloro's Avatar
alloro
There's an electrical issue keeping the compressor from running. This could be either the low or high pressure switches, low refrigerant, or the compressor relay could be bad. Once the compressor is running, if you still don't get cold air, it is possible you have a broken blend door. That was a big issue with these vehicles.
Old Aug 9, 2025 | 09:08 PM
Awar's Avatar
Awar
Bad compressor clutch relay is a common failure.
cheese4420
Jul 9, 2012 07:29 PM
