C6 yoke and U-joint replacement
Old Jul 29, 2025 | 08:55 AM
JJFizzle's Avatar
JJFizzle
I replaced the tail shaft seal and bushing on my C6 (1978 F100), but a leak has returned. I'm thinking the yoke has been worn down slightly over time - although I'm open to other ideas.
I see 31-spline replacement yokes ranging from $60 to $200. Any recommendations? The overall length matters too, huh? I'll have to pull the yoke again and measure. Do I measure just the length of the smooth shaft?
Beyond that - I'll need a new U-joint. So I'll measure that too. The new bushing only has about 30 miles on it - so I plan to reuse that and hope for the best.
Thanks!
Old Jul 29, 2025 | 09:16 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Just a SWAG, it might be time for a Spedi-Sleeve on the yoke??
Old Jul 30, 2025 | 08:45 AM
JJFizzle's Avatar
JJFizzle
I'll check those out. At first glance, they look pretty stubby. Maybe they don't need to extend all the way into the shaft - just where the seal touches. Thanks!
Old Jul 30, 2025 | 09:18 AM
tbear853's Avatar
tbear853
But that area "where the seal touches" changes with each and every bump in the road, every dip, every load change, every take off from a stop, every hard braking ... as the slip yoke moves in and out. If the sleeve is narrower than the length of the yoke's travel area, it's lip might itself be a seal killer itself as it passes that seal lip.
william16339
Aug 10, 2017 11:01 AM
73FOMO
Dec 23, 2012 08:16 AM
Karm239fh
May 2, 2005 05:12 PM
HardFordCore
Oct 17, 2003 11:03 PM
joecanuel
May 11, 2002 12:25 AM
