Switched power source
Old Jul 27, 2025 | 11:00 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes the above pic is the dvr side and yes it is 12V switched power- aka (keyed power/key turned to the 1st position) (run) powered elec connection. There is another one behind the glove box area that is simular. 2 wire, to a black 3 hole plug constant 12V power. That is what powers the glove box light and then a splitter is used to come down and over to 1 wire power the cig lighter, leaving 2 holes open.
Below is a none a/c truck.
1979 Bronco a/c equipped and that is the same as above 12V constant power. It has enough to get down from behind and below the dash. This below was with the a/c evap box removed. Would be hard to without removing the glove box liner.
Yes the dvr side, one wire yellow 12V keyed power, can be hard to locate.
joe speed
Sep 5, 2021 07:59 PM
2012 F250 6.2
Aug 29, 2021 09:54 AM
joe speed
Jun 9, 2021 02:42 PM
Fifty150
Transit Connect
Jan 24, 2021 04:01 PM
Squirrel13
May 19, 2020 12:01 PM
