Sidewall damage - replace tire?
Old Jul 24, 2025 | 08:59 AM
epear's Avatar
epear
7th Gear
I rubbed a curb last night pretty good. Left a small gash in the sidewall of my rear passenger tire. I can't see any of the steel cords in the tire, but not sure if it warrants a new tire. I understand that sidewall damage is the worst kind of damage... I do tow and am about to head out on a 1000+ mile trip. 2018 F-250 6.2l 4x4. Thanks for the input!
Old Jul 24, 2025 | 10:15 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I have driven on worse, BUT if it troubles you I would say go ahead and replace it. That's deeper than I'd feel absolutely safe with. Like if I had no other choice I'd use it, but if there were an option to NOT use it, I absolutely wouldn't.
Old Jul 24, 2025 | 10:56 AM
speakerfritz's Avatar
speakerfritz
I think any tire expert would tell you its not worth the risk and they would recommend replacing the tire ...rather applying arm chair internet knowledge like heating up the tire with a hair dryer and applying hot black hot glue on it
Old Jul 24, 2025 | 11:03 AM
Beast 17's Avatar
Beast 17
Replace it.
The tires on any vehicle are the foundation. Without tires it is yard art. Your life is more valuable than a $300 to $500 tire any day. Blown tires can pull you into a head on or ditch collision let alone pulling a trailer with your family. A lot of people complain about the price of tires but they are simply cheap insurance.
Old Jul 24, 2025 | 01:15 PM
epear's Avatar
epear
7th Gear
Thanks for the feedback guys. My gut was telling me to replace as well, I just won’t be comfortable on the road knowing that damage is there. At the tire shop now.
I will say that another shop I stopped at to inquire about said it was fine and to not worry about it… I was kinda surprised at that answer. Needless to say I might not use that shop anymore.
Old Jul 24, 2025 | 03:41 PM
406f150's Avatar
406f150
Hard to give a good answer on just a picture, but if it concerns you throw it on the spare if you don't have a matching sized one on there.
Old Jul 24, 2025 | 06:22 PM
bigwin56f100's Avatar
bigwin56f100
Replace but keep old tire and look for a spare matching wheel then you have a matching tire/rim combo ready to go if you ever need it
Old Jul 25, 2025 | 09:01 AM
Sport45's Avatar
Sport45
I don't think there's an in-between. If it's good enough to use as a spare it's good enough to run on the ground. And that one looks good enough to me. The OP said the plies aren't exposed and I figure he'd say if it was losing air. That isn't a structural part of the tire.
Old Jul 25, 2025 | 11:25 AM
Qwkynuf's Avatar
Qwkynuf
I think that looks like one that I would feel pretty comfortable running around town unloaded with, but the OP is talking about taking it on a 1k+ mile trip. He mentions towing, but not whether he would be towing on this trip.
*My* luck would be that I would hook up my 5th wheel, hit the interstate, and it would be fine until I was the largest distance that I could get from a tire shop....then I would hit a pothole on that EXACT spot and blow out the sidewall. But that's just my luck.
Old Jul 25, 2025 | 07:25 PM
DSLTRK60's Avatar
DSLTRK60
Perfectly fine to run that as is, doesn't meet DOT damage required for replacement as it's just a small nick in the rubber and no casing is exposed. Use it as the spare?
Old Jul 25, 2025 | 10:08 PM
2021F350's Avatar
2021F350
Ah no... It's NOT the same... Not in my book anyways. A spare tire is a tire, to get you to a place where you can get your flat tire fixed, Now some people do use the spare tire in a regular rotation, but normally most spare tires, especially lately are emergency use only... Not so much in 1 tons but, after years and years, even un-used "new" tires it can deteriorate to the point where it is not reliable... JMO...
Old Jul 26, 2025 | 08:12 AM
Sport45's Avatar
Sport45
Right. But tire stores, the ones I shop at anyway, aren’t open 24/7 so that spare might have to last all day on the freeway some +100° Sunday. My spare has to be able to do anything the other four can. The only difference is it’s on a steel wheel and doesn’t look as nice.
Old Jul 26, 2025 | 09:12 AM
Joe T's Avatar
Joe T
I would run it. That just looks aesthetic to me.
Kinda ugly so maybe take this time to throw it up into the spare compartment if you don’t have a matching size spare.
Or flip it.
Might as well do a full balance and rotate before your trip too….
RV_Rob
May 14, 2024 10:54 AM
Briansshop
Mar 28, 2023 10:37 AM
dannyual767
40
Dec 24, 2021 12:40 PM
Mike SVOR
Aug 28, 2007 04:33 PM
